83 B150 Ram Slant 6 Misfiring after doing EVERYTHING! Frustrated! Pls Help!!!
Old May 17, 2009 | 03:28 AM
  #32
Polaradude's Avatar
PULL THE VALVE COVER
Old Jun 20, 2013 | 09:03 PM
  #35
IF you can find someone with an old scope that knows how to use it ? would be the way to go. Most garages have gotten ride of them
Old Aug 7, 2013 | 02:15 PM
  #36
"I noticed the canister that goes into the electronic ignition module that has a vacuum line going into it from the carb is a little broken on the right-side mounting point but mostly stays in place...but I think that's still pretty much working to advance the timing, and I don't think that would cause it to miss on only one cylinder at idle. Right?"
I wonder ? Does it have a lean burn setup ???
Old Sep 28, 2014 | 08:08 PM
  #37
Bgulseth1971's Avatar
Did anyone figure this out I'm having a miss fire too.
Old Feb 6, 2021 | 08:23 PM
  #38
billy popcicle's Avatar
Unhappy ram van b150
im having the same problem with my 81. except in idle it runs fine but when i put it in gear its missing or feel lkike it any way help?
  #39
jm2576
Jul 20, 2020 12:30 PM
Barfly
Jun 4, 2010 10:04 AM
bigsho
Sep 17, 2009 06:32 PM
theaspenator
Feb 1, 2008 07:46 PM
