building my first 440, what kind of power???
Old Apr 8, 2013 | 08:28 AM
mebebob's Avatar
1974 440.C.I.D.
Lower end. KB 237 pistons .040 over, fully balanced, stock rods and stock crank. just turned.
902 heads 88cc's Motor should be right around 9.7 :1 compression ratio.
Full valve job of heads.
stock rockers and stock valves.
camshaft Comp kit K21-221-4 kit from summit racing.
lift .447int. and .455 exh.\
lobe separation 110
duration @50 212int. 218exh.
Aluminum intake
mopar performance ignition
What kind of hp and tq numbers can I expect from this build.
Old Apr 8, 2013 | 02:26 PM
mebebob's Avatar
Anyone know what kind of horse power and torque this motor build should make!!
Old Apr 8, 2013 | 02:42 PM
My guess is 350 to 380 hp.
Old Apr 11, 2013 | 02:20 PM
mebebob's Avatar
Anyone one else have an idea of what sort of power this motor will make...
Thanks
Old Apr 13, 2013 | 09:05 AM
yea, 360-390 range is a pretty safe assumption.
Old Apr 13, 2013 | 07:30 PM
Gorts 5th's Avatar
Smile
Originally Posted by moparted
but a motor in another post with stock pistons has 400?
Yep
Old Apr 15, 2013 | 09:52 AM
there are so many factors, such as head work, cam choice, compression, etc. I don't know what the other engine had as far as tricks, but a 440 running 11:1 compression, all other components relatively equal, is going to put out a gob more power than one running 9.7:1. just for instance.
Old Apr 16, 2013 | 12:08 PM
Charger Dana's Avatar
1) That's a small cam.
2) It's all in the heads.
3) Bottom end is probably fine, but pop-top pistons would increase your compression.
You could easily push that to 500 hp, depends on what you want to do with it- street, strip, street/strip, pump gas etc.
ewnelson
Sep 6, 2013 01:36 AM
98 SNAKE EATER
Mar 20, 2013 05:10 PM
mebebob
Mar 28, 2012 12:16 PM
tommy383
Aug 4, 2009 01:14 PM
cuda69
Cuda Specific Discussion
Nov 23, 2008 04:10 AM
