Castng #'s Questions
Old Sep 30, 2014 | 09:26 AM
Robert Weaver's Avatar
Question Castng #'s Questions
Hello,
I've double check these #'s and wanted someone to double-check me please.
Much Appreciated...
My 1974 Charger SE Baby Blue White Top
VIN # = WP29K4A170230
Block Cast # Driver Side = 2532630 = (318)?
Head #'s = 2843675 = (318)?
Manifold # = 3698437 ?
Old Sep 30, 2014 | 03:22 PM
What is all this?
I've got an A block 318 not an LA, 318 head and a 360 2V manifold.
I didn't look at VIN.
Old Sep 30, 2014 | 04:57 PM
Thats what is on my 74 Charger. Crazy isnt it.
Old Sep 30, 2014 | 05:17 PM
If you have a head off measure the bore and stroke. A steel ruler should be able to show the difference between 3.91 and 4, and for sure 3.31 and 3.58 inches.
Old Sep 30, 2014 | 05:28 PM
The guy at the engine shop gave me a bad 4.00 piston the check with. It won't fit into my cylinder walls, it's just a hair to big.
Old Sep 30, 2014 | 05:53 PM
Check your stroke.
VIN says Charger, premium, 2dr sport hardtop, 360 2bbl.
Old Sep 30, 2014 | 06:04 PM
It could be that the engine was swapped long ago.
Old Oct 10, 2014 | 04:07 PM
If my intake is a 360, which gasket set would i use? 318 or 360?
Old Oct 30, 2014 | 07:25 AM
This has turned out to be quit interesting and also unveiling.... From My Sources
The Block 2532630 casting was built from 1956-1966 as a 318A engine ( A Poly H.D Block if you will)....
The Head 2843675 casting was built from 1968-1974 as a 273/318 STD Iron head...
And someone exchanged it as a transplant into you 1974 Charger...
Wow.....If someone were to ask me if this combination of parts would work together? I would have told them that they where Nuts in the head to try....lol
With that said. It appears that you have got it up and running...
Old Oct 30, 2014 | 07:43 AM
I know crazy isn't it. Also, the drivers Head is a 318 with the emission holes plugged.
Old Oct 30, 2014 | 06:59 PM
moparted's Avatar
la heads don't fit on an a block, no way, no how
Old Oct 30, 2014 | 07:02 PM
All I know is that the heads I've got work.
Old Oct 30, 2014 | 07:21 PM
moparted's Avatar
then your reading some numbers wrong. post pics
Old Jan 19, 2015 | 02:13 PM
Can the poly 318 motor work in and newer vehicles besides the rams?
Old Jan 19, 2015 | 02:50 PM
moe7404's Avatar
in the late 60s i knew an old chrysler parts man. he said that at the factory the casting no was only good till they started to machine the part. my guess is that the casting could be machined into more than one part no. just my guess.
Old Jan 19, 2015 | 03:05 PM
Hummmm.... That will take some fab work... Why a "Poly" ???????
The LA block and Magnum Blocks are far more common !!!!!
MoparMan76
Jan 14, 2011 01:31 PM
