Elect Fuel Pump Question
Old Jan 14, 2011 | 01:34 PM
Frank's 69's Avatar
Hey, Any tips on where to mount a malory elect. fuel pump, and filter? I'm gonna draw from a 1/2 in pick up, from a stock tank. TTI exhaust to the rear. If anyone knows of a web site, or can shoot me a photo of a b-body with a neat elect pump set up, Frank would greatly appreciate it. THANKS!!!
Old Jan 15, 2011 | 04:56 AM
rdrunner1974's Avatar
Fuel pump
Recently did this for my son-in-law on a non Mopar. Mounted the pump at rear on frame with filter B-4 pump ( in between tank and pump)
Also used a pressure regulator mounted on firewall with a return to tank and another filter at lie to carb.
Was not a Mallory pump but we have good volume and pressure-clean fuel to a 454.
Old Jan 15, 2011 | 05:58 AM
Everything I have "been told" is that all electric pumps are better at pushing fuel than sucking it... I have always placed the pump as close tothe tank as possible and always put a filter between the two....
Old Jan 15, 2011 | 11:29 AM
Silverick's Avatar
X2
Old Jan 15, 2011 | 07:30 PM
scotts74birds's Avatar
Just wanna say that electric pumps on a street car can pose problems. In the event of an accident, the pump wont shut off. Scary consequences!
Old Jan 16, 2011 | 06:27 PM
bentman's Avatar
I mounted mine under the passenger seat on the frame it's a holley red pump
Old Jan 17, 2011 | 10:25 AM
Well that's easy to fix. You should be running through the ignition switch and a relay so that's safety device no1
You can then run the relay coil through an oil pressure switch, easy to do, so that's no 2
Finally, you can easily get a "crash switch" (My Ranger switch is mounted up under the dash, easy to get to) and wire that in series with the relay coil, so that's safety no3
4Doba
Jun 25, 2011 11:35 AM
softball
Oct 8, 2010 08:23 PM
1971challenger
Apr 24, 2010 09:34 AM
mopars&vampires
Jun 23, 2009 09:31 PM
rapidride2
Mar 20, 2007 05:58 PM
