gear ratio for 67 Coronet
Old Mar 24, 2023 | 08:47 AM
Caleyedge's Avatar
I need more performance than my 2.94 gear ration is providing. 1967 Coronet, 383 with 727 3 speed automatic. Suggestions of how big before being too big? 3.55 or can I go higher?
Old Mar 24, 2023 | 09:06 AM
You can go as high as you want, I have 4.88s in my Volare but you will not find me anywhere near the interstate with it. If your 383 is stock or a mild build a 3.23 or 3.55 are good street gears, if gas mileage isn’t a concern and your cruising is 55 miles an hour or so 3.55 or 3.73 gears are a blast.
So 3.55 is a good compromise gear, and probably what I go with unless you are planning a 500hp build for your 383…
Old Mar 24, 2023 | 10:46 AM
I like the 3.91 gear set.... Good for the large heavy cars...
Old Mar 24, 2023 | 12:24 PM
I had a set of 4.10s in a 77 royal Monaco at over 5000 pounds it ran low 15s with the smog 440…!
Old Mar 24, 2023 | 06:16 PM
Archer's Avatar
Cal -
What RPM will you be comfortable with on the highway?
I ran 3.23's for decades on a 2 ton+ Charger with a modified 440.
Worked well, but recently switched to 3.91's - runs better, @ highway speeds, 3000 is about average, but remember it's a built 440.
3.23 will show a mild improvement, 3.55, 3.73 are mid range and 3.91 is about as high as I'd go with a non-race car.
Old Mar 24, 2023 | 07:31 PM
Back in the sixties the 3.91 set was a popular OEM performance option.
Old Mar 25, 2023 | 10:16 AM
I do like most all the 4.XX raito's, But like all have said, Those you have to ready to use a bit more RPM when driving out on the Highway or Interstate..
And the Fuel mileage goes away pretty quickly.... But if you got on of them big old honker camshafts that start the rpm range at around 3000 rpm and that about were the converter in locked in.... Then you can run a 4.30 - 4.88 gear and do ok...
It just take some planning ad some adjustments that always leads to more fun money....
Keep us posted.....
Cheers
Old Mar 28, 2023 | 11:26 AM
i have found, in almost all apps, that 3.55 is a great universal ratio. not mild, not wild, just right.
Greg N
May 29, 2021 07:55 AM
josehf34
17
Jan 1, 2015 01:04 PM
dgbcharger
Oct 18, 2014 11:52 PM
kgraham
Nov 25, 2013 07:41 PM
19newport72
Feb 19, 2013 05:54 PM
