Head Lights shorting out on 73' Satellite! Can anyone help?
Guest
Posts: n/a
I recently cleaned my taillight buckets out, I sealed them, steel wooled the connections, and rewrapped the wiring in electrical tape. Everything seemed to be working fine. Then I was driving with the headlights on when suddenly, while turning on my blinker, the headlights, and front ambers went out. Also on the dash, the turn signals came on with a bright steady glow, and the brights indicator came on.
I checked the fuses, and nothing is blown. I replaced the brights switch, that did not help. Then I changed the headlight switch with a new one. That fixed the problem! However, I started driving and they went right back out again!
Does anyone in MoPar land have a suggestion? I could use any tips, because my wiring harness is old, and has many patches. So, following it with a tester will be tedious. I eventually want a new Painless Harness, but would like to get on the road. One last thing, it is definitely drawing on my battery. Thanks-
Kidcoyotearm
Kidcoyotearm
rcknrolfender79
Jun 7, 2022 08:17 PM
AliceSML79
Aug 22, 2014 03:28 AM
Nate Ryan
Aug 21, 2013 02:15 PM
1966charger
Apr 22, 2012 08:27 PM
67 Fury
Jan 7, 2010 10:29 PM
