HELP! losing power, battery not charging
Old May 31, 2009 | 01:52 PM
blue 68 gts's Avatar
How are the plugs?
Plug wires?
Distributor?
Coil?
Coil wire?
-nick
Old May 31, 2009 | 02:15 PM
Polaradude's Avatar
Hey Bee, is the car stalling out ? or is it loosing charge when parked say overnight ? A little more info would help, and welcome to the forum.
Old Jun 1, 2009 | 02:53 AM
Polaradude's Avatar
It's starting to sound like the regulator/bad ground.
Old Jun 1, 2009 | 08:48 AM
Crazy4Carz.Com's Avatar
Your headlights and ignition are both fused via the fuseable link. (probably not that)
I am only guessing, but I believe the alternator is not putting out enough power at low idle. Jump start the car, crank the idle up to about 1500 (just for the test) disconnect the battery and see if that is OK. My guess is that will keep running and make enough power to charge and run the car. There are different size (diameter) pulleys that come on alternators. My guess yours is sized such that the alternator is spinning too slow to make the power you need. if this is the case, swap the pulley or change to an alternator with a pulley same as spec should be.
Plugs, coil, and ignition parts have no affect on charging.
Old Jun 1, 2009 | 09:34 AM
Polaradude's Avatar
It's probably what Steve said but do you know output voltage at the Alt. ?
Plugs, coil, and ignition parts have no affect on charging...beautiful Steve...lol
raycan2
Apr 4, 2014 02:59 PM
383newport
Aug 22, 2012 02:59 PM
starfleet
Feb 7, 2011 07:35 PM
Jonny
Nov 12, 2010 01:13 PM
Satellite_Guy
Sep 9, 2008 07:00 PM
