info requested re: 361ci dodge engine
Old Mar 9, 2009 | 10:42 PM
theomahamoparguy's Avatar
Originally Posted by bighammer
I am new to MOpars; just bought my first: 1970 Dart 318 auto.
My question is regarding an engine I just aquired. It is a 361ci that came out of a 63 dodge ( I beleive). It has been stored inside the shop for about the last 25 years. Back then I got to hear it run; we were going to put it into a sand rail, but it never happened.
I think the bore on the 361 was somewhere near 4.120 and the stroke was the same as the 383. The block deck height was the same as the 383 also. Actually this engine could be viable if you could find pistons for it. That would be the hard part. As far as putting it in the dart, that would not be a problem. If the engine still runs good, you could put it in the dart then start building a 383 for a future replacement. The 383 is alot easier to find pistons for.
How to you plan to use the dart? Show? Cruiser? Drag car?
Old Mar 10, 2009 | 03:24 AM
Welcome to the forum Big.
There are parts out tehre for the 361s but they are going to be like all mopar parts are, hard to find and costly. If it still runs and is in good shape (just needs to be cleaned up and new seals) then I would say its worth it.
I would tear it down and see what it really needs to get it running again. If you start to make a list of parts it needs, then your going to have to weight that and the time and machine work (if needed) against keeping the 318 or swapping it for another motor.
If its not worth it, I would look for a more coomon motor. Like moparguy asked, what is your intent with the Dart?
Old Mar 10, 2009 | 06:09 AM
Commando's Avatar
Are the carb and headers the only modifications to the engine, as it could already have different internals and only require new seals and be good to go.
Old Mar 10, 2009 | 11:26 AM
A mopar BB will not bolt up to a mopar SB tranny. They are different bolt patterns and size.
What I meant was that parts for that 361 are going to be harder to find than parts for a 383. There are less parts out there for mopars when compared to c$*@y and F!&d. Plus I have noticed that most of the time, mopar parts cost more than the other two.
Since you already have a cam and carb and want to do headers and exhaust, I would throw on an intake (if you have just a factory intake now) and call it a day. You want the car to be a fun cruiser and that 318 will be just right for it. If you want more fun, then look for a 340 and build that up.
Old Mar 10, 2009 | 02:17 PM
you could just bore out (i think it was bored out) the 361 to 383
Drakovich
May 15, 2011 08:59 AM
1OldFordMan
Dec 23, 2009 10:35 AM
scampdude
Jun 6, 2008 08:03 PM
71charger
Apr 2, 2008 05:22 AM
sinister
Jan 15, 2008 09:42 PM
