Jack points 1965 Dodge Coronet
Old Aug 23, 2011 | 10:17 PM
robin henkel's Avatar
Hi ... I'm glad to have found this forum,
Where are the safe jack points for a floor jack and jack stands on a 1965 Dodge Coronet. I have the 1965 owners booklet but it only shows where to position the tire changing jack. I'd like to lift the car up and place jack stands behind the front wheels to do an oil change. Is the flat metal area under the motor a safe spot for a floor jack?
Thank you
Old Aug 24, 2011 | 12:41 PM
If you are referring to the k-frame, then yes. Oil pan, no. Don't forget, if you are going to be under the car, it is safest to also use a locking jack. Jack the car up with the hydraulic, but dont rely on it. If it somehow fails, then the car will fall.
tripleblack
Apr 3, 2012 08:49 PM
67440X
Apr 1, 2011 03:21 PM
mach3107
Feb 9, 2011 11:10 AM
RROriginals
May 28, 2010 08:03 PM
puffbunny
Feb 5, 2007 10:54 AM
