Kickdown linkage
Kickdown linkage
Is there a proper way to adjust the kickdown linkage???? I installed a highrise aluminum intake and 4bbl carb on my 72 Satellite, 318cid, 904 trans. The kickdown is controlled by a rod with a slotted end attached to the linkage that I had to reshape to compensate for the taller intake. I just cant seem to get my shift points back to normal. Also dont remember was there a spring to hold that kickdown linkage forward when the throttle is closed????????
lokar
I have a 4" high rise and I used a Lokar setup. When I did the adjustment I made small ones until I had the passing gear kick in when the secondaries opened. It works pretty sweet. The only problem I ran into was a slight stall at that point but a MSD set up cured that. All for about $225
