Kickdown linkage
Old Oct 28, 2009 | 06:02 PM
72sat's Avatar
Kickdown linkage
Is there a proper way to adjust the kickdown linkage???? I installed a highrise aluminum intake and 4bbl carb on my 72 Satellite, 318cid, 904 trans. The kickdown is controlled by a rod with a slotted end attached to the linkage that I had to reshape to compensate for the taller intake. I just cant seem to get my shift points back to normal. Also dont remember was there a spring to hold that kickdown linkage forward when the throttle is closed????????
Old Oct 28, 2009 | 09:02 PM
old tired rebel's Avatar
I just put a 360 4bbl intake and a Edelbrock 600 on mine and now I have to get the 4 bbl kickdown linkage from a 318 car. A Friend brother helped by going to the Junkyard to get one for me.
Old Oct 29, 2009 | 03:28 AM
OutlawCuda's Avatar
Senior Member
There is a way to set it up correctly , I can send you the info from the service manual if you want?
Old Oct 29, 2009 | 05:50 PM
72sat's Avatar
Yeah, OutlawCuda, if you can send me that info I'd appreciate it.....Thanks
Old Oct 31, 2009 | 11:20 AM
pjmopar's Avatar
Can you put the proper way to adjust the kickdown linkage on this site for all to see.Thanks
Old Oct 31, 2009 | 12:56 PM
That would be a great idea. One of us mods can make it a sticky too.
Old Oct 31, 2009 | 03:19 PM
Heck of a idea cause I am changing mine next week.
Old Oct 31, 2009 | 04:56 PM
OutlawCuda's Avatar
Senior Member
I will be in the shop Sunday , I had anouther 9hr. day at the Big Cheese ! I will get the info on in the am hours. Have a good eve.
Old Nov 1, 2009 | 09:46 AM
OutlawCuda's Avatar
Senior Member
Hi Kick down Mopar adjustment group, I am having a problem getting the pictures big enough for you. I will try something with photo bucket.
Old Nov 1, 2009 | 03:13 PM
OutlawCuda's Avatar
Senior Member
Ok Let see if you can use this>
Attached Thumbnails Kickdown linkage-blue-point-276.jpg   Kickdown linkage-blue-point-277.jpg   Kickdown linkage-blue-point-275.jpg   Kickdown linkage-blue-point-274.jpg   Kickdown linkage-blue-point-273.jpg
Old Nov 1, 2009 | 03:17 PM
OutlawCuda's Avatar
Senior Member
If the posts dont work let me know and I will try something else. Sorry for the delay. I am not to sharp with this computer stuff. The info is from 70 and 76 service manuals.
Old Nov 1, 2009 | 06:27 PM
Thanks OC
Old Nov 2, 2009 | 03:20 AM
OutlawCuda's Avatar
Senior Member
Thumbs up
Your Welcome
If you have a problem just ask and I will try and help any way I can. Have a Good Week !
OutlawCuda
Old Nov 2, 2009 | 05:43 PM
72sat's Avatar
Thanks, for the help OutlawCuda.........
Old Jan 9, 2010 | 05:03 PM
kids mechanic's Avatar
Junior Member
lokar
I have a 4" high rise and I used a Lokar setup. When I did the adjustment I made small ones until I had the passing gear kick in when the secondaries opened. It works pretty sweet. The only problem I ran into was a slight stall at that point but a MSD set up cured that. All for about $225
KJoeZ61
Sep 27, 2009 05:07 PM
Iskone
Jul 4, 2009 08:25 AM
nesparky
Jun 2, 2009 08:26 AM
DartConvertible
Mar 28, 2008 06:24 PM
button
Jan 26, 2008 05:30 PM
