motor swap
A lot. The complete drive train should be changed. I believe the 64 still has the rear drum axle bolts SO the rear end - there again is the transmission problems with shift linkage unless you go aftermarket shifter.. drive shaft, engine mounts, radiator, some block huger headers and all the little details
sixfive407
Aug 31, 2010 02:19 PM
koondawg_74 roadrunner
Jul 3, 2009 10:49 PM
