need help with 383
Old Apr 22, 2012 | 08:19 PM
68 charger's Avatar
need help with 383
hi
new here need some help. machine shop said it is 433 383 block .040 flat tops 440 crank . 906 heads. don't know cam size. has dual quad intake carter 390cfm carbs. 727 2000rpm stall. can't get to run right stumbles like turn off then go's. backfires if timing is under 45 btdc. tried single 4bl intake still same problem. up metering rods got better power but still stumbles.
appreciate any ideas thanks
Old Apr 23, 2012 | 05:01 AM
PK1's Avatar
PK1
1. Who put dizzy in? Was it indexed correctly?
2. Back fires thru the intake or out the pipe?
3. Does it idle and what is your vacuum at idle? Whats the needle doing?
Old Apr 23, 2012 | 08:44 AM
68 charger's Avatar
thanks for help. I put distributor in it's stock. had Mallory dual point ran worse. backfires in intake. exhaust was popping be for upping metering rods. idles ok at 800rpms at 550 really lopes. don't have vacuum gauge. checked for vacuum leaks don't see any. sorry for not having all info.
Old Apr 23, 2012 | 11:05 AM
Archer's Avatar
68 -
Kinda sounds like you've got a couple of plug wires crossed.
Old Apr 23, 2012 | 12:00 PM
68 charger's Avatar
just checked wires look ok 18436572
labradorian70
Sep 24, 2014 09:44 AM
Rumblefish318
Jun 30, 2013 12:56 PM
Valex9499
15
May 20, 2013 08:38 PM
shoreboy85
Aug 23, 2011 09:13 AM
wyattmerk
Dec 1, 2008 05:19 AM
