Performer RPM Heads
Old 03-15-2010 | 07:02 PM
Slice's Avatar
Performer RPM Heads
Does anyone have specs on the valve springs that come with Eddie RPB Perf?
Old 03-16-2010 | 12:14 AM
1966sportfury's Avatar
A.K.A Bob Dodge
this is all i got sb diameter 1.46" max lift .575"
magnum sb 1.46 diameter max lift .580"
bb rpm heads dia, 1.55" maxlift .600"
Old 03-16-2010 | 03:02 AM
Slice's Avatar
Thanks, I also got that info from the Edelbrock site, but I'm trying to find out if I can use them with a comp cam that lists a dual spring. The Eddie heads have a single spring and dampener.
Old 03-17-2010 | 12:26 AM
A.K.A Bob Dodge
call comp cams im sure they will be more than happy to tell you. thats what i would do go strait to the source 1st comp then edel
Old 03-20-2010 | 04:15 AM
phatdak18's Avatar
yea thats what i did too. I got those same heads, i called comp n told em what i had and what i wanted to do with the car. They go ahead and figure everything out for you and before ya know know it the ups guy is at your door.
shone190
07-23-2014 06:29 PM
usedknobby
05-23-2013 08:34 PM
usedknobby
05-23-2013 06:41 PM
B Green
04-01-2013 04:07 PM
shizam
03-15-2010 12:47 PM
Quick Reply: Performer RPM Heads
