Performer RPM Heads
Old Mar 15, 2010 | 07:02 PM
Slice's Avatar
Performer RPM Heads
Does anyone have specs on the valve springs that come with Eddie RPB Perf?
Old Mar 16, 2010 | 12:14 AM
1966sportfury's Avatar
A.K.A Bob Dodge
this is all i got sb diameter 1.46" max lift .575"
magnum sb 1.46 diameter max lift .580"
bb rpm heads dia, 1.55" maxlift .600"
Old Mar 16, 2010 | 03:02 AM
Slice's Avatar
Thanks, I also got that info from the Edelbrock site, but I'm trying to find out if I can use them with a comp cam that lists a dual spring. The Eddie heads have a single spring and dampener.
Old Mar 17, 2010 | 12:26 AM
A.K.A Bob Dodge
call comp cams im sure they will be more than happy to tell you. thats what i would do go strait to the source 1st comp then edel
Old Mar 20, 2010 | 04:15 AM
phatdak18's Avatar
yea thats what i did too. I got those same heads, i called comp n told em what i had and what i wanted to do with the car. They go ahead and figure everything out for you and before ya know know it the ups guy is at your door.
shone190
Jul 23, 2014 06:29 PM
usedknobby
May 23, 2013 08:34 PM
usedknobby
May 23, 2013 06:41 PM
B Green
Apr 1, 2013 04:07 PM
shizam
Mar 15, 2010 12:47 PM
