REAR END SWAP QUESTION?
Old Mar 8, 2011 | 07:16 PM
THE GOOSE's Avatar
I HAVE A 72 CHARGER WITH A 318 AND 727 AND P245/60R14 TIRES.
IM NOT SURE WHAT REAR END I HAVE, IM GOING TO HAVE TO LOOK.
ID LIKE TO GET MORE POWER BY CHANGING REAR ENDS AND WAS WANTING TO KNOW WHAT REAR END I NEED AND OUT OF WHAT VEHICLE.
AND IS THERE A NEWER ONE WITH DISC BRAKES TO LOOK FOR?
THANKS FOR ANY INFO
Old Mar 8, 2011 | 07:30 PM
MercuryDon's Avatar
You should have a 8 3/4. It will have a pumpkin instead of a rear cover.
Old Mar 8, 2011 | 07:38 PM
THE GOOSE's Avatar
HERES A PHOTO OF MINE.
Old Mar 8, 2011 | 07:40 PM
Reese's Avatar
THANKS FOR ANY INFO
I have the same rear end (8 3/4) in my 69 Charger and its a decent rear end. I put 3.91/489 case w/ sure grip in mine and it works perfect. You can get a Disc Brake conversion kit and put them on instead of the drum brakes.
Old Mar 8, 2011 | 07:44 PM
THE GOOSE's Avatar
CLOSER PHOTO
Old Mar 8, 2011 | 07:50 PM
MercuryDon's Avatar
That is not an 8 3/4 it has a rear cover. It most likely a 7 1/4. I'd get a 8 3/4 if you gonna do any HP mods.
Old Mar 8, 2011 | 07:51 PM
68 Sat's Avatar
my 8 3/4 looks different on my 68 satellite. I also have a 318 car with a 318 and an 8 1/4 rear that looks just like your pic. I would dble ck that.. pic is 8 3/4
Attached Thumbnails REAR END SWAP QUESTION?-ry-400-1-3-.jpg   REAR END SWAP QUESTION?-mopar_axle.jpg
Old Mar 8, 2011 | 08:00 PM
THE GOOSE's Avatar
IS THERE A CERTAIN VHEICLE I SHOULD LOOK TO FIND A 8 3/4.
TO GET THE CORRECT WIDTH.
THANKS
Old Mar 8, 2011 | 10:08 PM
MercuryDon's Avatar
I have a complete 8 3/4. I'm in So California. I don't suppose you local here. If not Most any mid 60s to early 70s B body. If there is no cover on the back thats what your looking for.
Old Mar 9, 2011 | 10:38 AM
That's not an 7 1/4, it's an 8 1/4. Those are "not bad" for a 318, but if you ever upgrade the drivetrain, it won't be very heavy. Also, they use "clip" retained rear axles.
I'd look for an 8 3/4.
Old Mar 9, 2011 | 07:53 PM
theomahamoparguy's Avatar
the 71 and on chargers and other B-bodies have rear end that are wider than the earlier B-body rears (62 - 70). The rear end you should look for is one out of a Challenger (or 70-74 Barracuda) believe it or not. [70 to 74]. it is the similar width as your charger. slight mods to the perches will be necessary. although your 8 1/4 will be just strong enough for your 318.
Old Mar 10, 2011 | 02:59 AM
THE GOOSE's Avatar
the 318 is getting replaced in the fall for a 360. id rather give up the great gas mileage for more low end power. i could iust swap gears but thought it would be better to swap it for a better rear end with lower gears.
thanks for the info.
Mudslinging
Aug 20, 2012 07:06 AM
cudaracer
Apr 18, 2011 09:26 AM
Nomadci
Jun 23, 2010 07:22 PM
67gtxclone
Apr 27, 2010 04:57 PM
72_coronet
Jan 12, 2009 05:57 PM
