Right engine
Old Jul 6, 2014 | 03:09 PM
chuck1934's Avatar
Right engine
Is there a way of telling if 67 R/T has the original engine in it? I have been told that the cars starting in 68 the engine serial number was part of the vin.
I know that you can tell the year the engine was made by the letter on top front of the 67 engine. Also was told that the only thing different about a 67 R/T 440 was a little hotter cam.
Old Jul 6, 2014 | 03:58 PM
So far as I know, ONLY 67 HP 440s got "the good" heads, these were closed chamber, casting no. 915. That might be a clue along with the casting date on the engine.
Old Jul 6, 2014 | 04:43 PM
moe7404's Avatar
all so the 67 440 heads had bigger ext valves than the 66 440. and the 67 440 AFB carb had a velocity valve above the secondary plates but under the discharge nozzle. i think thats the only year with that set up. a VERY good set up. the AVS came out i 68. try setting the float level at 5/16. stock is 7/32. the float drop setting is not needed. cause the float hits the floor of the fuel chamber be for it can do any harm. but the needle and seat might lock when setting out in the open.
Old Jul 22, 2014 | 02:18 PM
moe7404's Avatar
my 1967 coronet factory service manual, shows. the 6 th digit K-- 440 ci in STD. L--440 cu in H.P.
Jeftam
Sep 13, 2011 05:58 PM
64fury
Jul 13, 2009 06:48 AM
siliconcrunch
Dec 1, 2008 10:57 AM
71RR08
Aug 22, 2008 12:10 AM
Billy Dean
May 21, 2008 11:41 AM
