Steering column light?
Old Dec 23, 2011 | 08:13 AM
MStep94765's Avatar
Question Steering column light?
Does anyone know if there is a light in the steering column that illuminates the gear indicator on a 69 440? I seem to remember there was one on my oringinal car, but that was 25 years ago and my memory may be wrong. My present one is dark and before I tear it apart looking for a bulb that isn't there, I thought I'd ask.
Michael
Old Dec 23, 2011 | 08:32 AM
I'm absolutely sure all of these are lighted
Here's a 69 (Dodge) service manual posted over at A bodies
http://www.abodyjoe.com/pictures/Mis...e%20manual.pdf
However, while it does show dissasembly of the column, I didn't see one word in there about replacing that lamp, or even the pointer assembly.
Old Dec 23, 2011 | 08:49 AM
MStep94765's Avatar
Thanks. Should be interesting.
Michael
Old Dec 23, 2011 | 09:13 PM
70redbee's Avatar
I think the light in the column is part of a light package if I remember correctly.
Old Dec 27, 2011 | 11:08 AM
MStep94765's Avatar
Thanks. I tool a look at it over the weekend. No screws behind the PRND21 panel (no lens in front of it, either.) I took off the shroud to the dash and tried to remove the lower plate on the column, but it would only slide back and forth, not come out. I can see all the wires for the indicators in there, still not sure if there is a bulb for the panel. Going to have to wait until I have time to tear more of it down.
Michael
Old Dec 27, 2011 | 11:27 AM
I think if you remove the steering wheel you might find one mounted to the top of the turn signal cam. The light shines up towards the gear selections.
OHD
Apr 7, 2010 04:40 PM
skybolt
Aug 29, 2009 08:38 PM
66dartvert
May 1, 2009 09:13 AM
68 Sat
Dec 22, 2008 09:00 AM
68 Sat
Dec 21, 2008 08:30 PM
