Are these the right leaf springs??
Old Mar 26, 2013 | 09:01 AM
98 SNAKE EATER's Avatar
Question Are these the right leaf springs??
New leafs arrived today, but they look just as stacked as the Super Stocks I have on now
Also, if they are the correct stock replacements, which side is which?
Old Mar 26, 2013 | 04:07 PM
jacilynn_s's Avatar
look correct from here. The sides interchange actually. Some were marked with a L and R. If yours are not just install them. The bolts for the front of the bracket are 3/8 and love to snap off if you look at them wrong. Spray liberallity with a rust penetration leave sit, work back and forth each a few times spray more leave sit, chase threads with a tap and die set remove.
Hope you ordered the rear spring shackle kits as well. Most of the time one of the studs just wont cooperate and busts OR the rubbers are shot to hell. Word of advice the nuts are cheap to replace. I use a method that seems to work well. Heat up the nut with a torch. Install nut splitter so that it widens the nut since the splitter seems to bust if you try to crack the nut. Remove nuts, plate, work the springs back and forth side to side to get out of rubber that is most likely rusted nicely in.
I usually blast both shackles clean along with the front mount. Paint all parts rebuilders gray or satin black and install with new rubbers on shackle along with new dot peened lock nuts.
Just a note but those springs are actually in primer not paint. They will rust after a few months unless you put some paint on them.
Old Mar 26, 2013 | 04:47 PM
Question
According to Google
4452982 Right Side
4452983 Left Side
For some reason, the front bracket on mine doesn't look like an OEM piece
Is that what's supposed to be there?
If so, do I use the lower or upper mounting holes?
Well, I will now lol
Actually, I'll have to wait another day because I've got a transmission job taking up my lift
crmzendrgone
Feb 25, 2009 05:07 PM
rr69half6bbl
Jan 25, 2009 10:11 AM
trdavey
May 9, 2008 05:56 PM
89klr250
Mar 2, 2008 06:09 AM
Gator
Apr 26, 2007 07:10 PM
