Timing needed adjustment
Old Aug 3, 2019 | 11:43 AM
  #31
I have seen distributors that were just wore out. Check the movements and the bearings on the shaft.
Old Aug 3, 2019 | 12:24 PM
  #32
sendust's Avatar
I tried a vacuum pump and can get no resistance at all from the vacuum can. it just seems i am drawing open air. do i need a new vacuum can?
Old Aug 3, 2019 | 03:09 PM
  #33
sendust's Avatar
I know this has gone on for a while so hopefully this will be my last question im thinking my main issue is the stock distributor . I was wondering what replacement you guys would recommend. Attached are the specs of my rebuild . thanks for any advice pete
Old Aug 3, 2019 | 03:44 PM
  #34
The mopar electronic conversion distributor with the box and wiring.
https://www.manciniracing.com/ma361383400e3.html
Old Aug 3, 2019 | 04:21 PM
  #35
sendust's Avatar
Thanks for your help , part ordered and in soon if im lucky pete
Old Aug 3, 2019 | 06:54 PM
  #36
Archer's Avatar
Pete -
Good choice.
Old Aug 3, 2019 | 07:27 PM
  #37
Originally Posted by sendust
Could the weights be dirty not allowing for total advance? the car sits 7 months of the year and i have never touched the distributor, lastly should i upgrade the distributor and if so what would match a 383 ?
I dont think so... Your getting a 22* sweep.... So I dont think they are stuck, and you dont have the advance hooked up?
If the Motor Runs good up the RPM band to 2000 -3000... I would be looking possibly that the secondary on the carb might not be opening, If it's a Vacuum Secondary?
Old Aug 4, 2019 | 08:08 AM
  #38
nice job on that order. you'll never look back.
Old Aug 4, 2019 | 07:42 PM
  #39
Good Up Grade.... I Agree...
Old Aug 6, 2019 | 04:06 AM
  #40
sendust's Avatar
Thanks again, i will let you know when it is installed pete
cmrris
19
Nov 3, 2017 07:07 AM
mrzods13
Apr 17, 2014 09:45 AM
Gorts 5th
Dec 19, 2012 04:52 PM
SPICOLIE203
May 1, 2011 10:44 AM
SPICOLIE203
Apr 2, 2010 02:59 PM
