What is it, and where does it go?
Old May 15, 2022 | 09:33 AM
r&b's Avatar
r&b
Hello. I'm hoping someone can identify this part I found under my 72' Charger. It was laying on the garage floor after replacing the front (disks) pads, and rear (drum) brake shoes. My 'guess', is that it belongs somewhere along the 'routing' of the parking brake tensioning cable. You'll note, there is no 'bolt on' feature.
The parking brake cable, connector, and equalizer (adjustment rod), are intact and in place. However, the equalizer nut bottoms out long before the parking brake cable is taut, which leads me to think it's part of the cable routing.
If anyone can verify that this is indeed part of the parking brake cable routing, and 'where' it might go, (maybe with a picture showing the location and orientation?), I would greatly appreciate it.
Thanks, Rick
Old May 15, 2022 | 12:56 PM
r&b's Avatar
r&b
WOOT! WOOT! I have a 90% confidence level that I found what it is, and where it goes...
As suspected, it is part of the parking brake cable routing. I guess you can call it a "flat' style cable support hook, in lieu of the more common 'round' style support hook that i've been seeing on line. One end hooks into an oval cut out located on top of the transmission cross member (you can't see it, you have to feel for it), and the other end simply keeps the cable from flapping in the wind between the connector and the equalizer. From all indications, it appears to be a natural fit. It also lines up with a small crease in the parking brake cable caused by 50 years of wear. After making the necessary adjustment with the equalizer, the parking brake now works and the hook is firmly in place doing its job. Hope this helps someone with this style of cable hook.
Old May 15, 2022 | 06:18 PM
I think you’ve got it..👍
CafnutS007
Oct 19, 2021 11:11 AM
dgp_naples
Dec 29, 2013 05:56 PM
Rich Good
Nov 3, 2013 11:31 AM
JLanzino
Sep 6, 2009 07:49 PM
sirus444
Jun 2, 2009 05:55 PM
