1966 fury III questions
Old Mar 1, 2013 | 07:04 AM
dazzlesa's Avatar
I have a 66 fury III with 318 and auto tranny. I bought a rebuilt tranny locally and there is a couple differences that I hope you can help with. The tranny dipstick tube does not seem to match. Would you have one that works on mine? Also the electrical connection is different. Any suggestions?
Also any suggestions on the car exhaust down tubes?
I had bought a disc brake set and I want to add a brake booster. Where do I get the vacuum from?
Attached Thumbnails 1966 fury III questions-furry2.jpg   1966 fury III questions-furry3.jpg   1966 fury III questions-furry4.jpg   1966 fury III questions-furry5.jpg   1966 fury III questions-furry-tranny1.jpg
Old Mar 1, 2013 | 09:13 AM
I don't know about the dipstick, but the "electrial connection" means that they gave you a late (69/ later) transmission instead of an early (pre 69) trans
The torque converter may be different, so check things out carefully. The early converters had a smaller front snout. There may be spline differences in the input shaft, not sure.
If the converter fits OK, and you get the dipstick ironed out, you can simply hook your neutral safety switch connection to the center post of the 3 terminal switch. This switch on the later trans uses the outer 2 terminals for the backup light switch.
Old Mar 5, 2013 | 03:35 PM
moe7404's Avatar
i think the nose on the converter might be different. but the difference goes all the way into the front pump, and may be a difference in the crank , out put end, to, i think
MisterFury
Aug 23, 2012 06:30 AM
Arbiter343GS
Aug 1, 2012 08:23 PM
fury_19
Jun 25, 2012 02:53 AM
Arbiter343GS
Nov 11, 2011 02:12 PM
solm96@me.com
Jul 10, 2010 08:35 PM
