65 Fury I slant 6- new owner questions
Old Oct 14, 2009 | 05:23 PM
CoogarXR's Avatar
Junior Member
Hello,
On a whim, I bought a 65 Fury I. I have owned a million cars in my life, but never any mopar products, until today.
Anyway, this Fury runs pretty good, and held 75mph for the 100 mile trip home. I just wonder, the temperature gage reads high. The needle sits on the right end of normal. Not on the "hot" line, but on the very end of normal. Is this normal for a slant 6? I have heat in the car, and it's not boiling, so I don't think anything is really wrong, but I just get uneasy about gauges who's needles aren't centered
Also, the gas gauge reads empty, but occasionally reads correctly for a minute, then goes back to empty. I assume there is a bad connection or broken wire somewhere. Any common problems with these? I took the gauge out and the contacts were clean.
Thanks fellas.
Old Oct 14, 2009 | 05:57 PM
scotts74birds's Avatar
Hmmm. Does the temp gauge fluctuate at the same time? The mopes have a 5 volt regulator in the dash for the gauges. Might want to check that if you experience bad readings from more than one gauge.
Old Oct 14, 2009 | 06:01 PM
do you know what thermostat is in the car?
Old Oct 14, 2009 | 06:37 PM
CoogarXR's Avatar
Junior Member
The gas gauge fluctuates independantly of the temp gauge. But just out of curiosity, where is that regulator?
I don't know what thermostat is in there.
Old Oct 14, 2009 | 07:37 PM
On the back side of the instument panel.
Old Oct 15, 2009 | 03:19 AM
You can always put a thermometer on one of the hoses when the car is at temp and see what it is reading. This will give you a good idea of what the temp is and what you have for a thermostat int here. As for you gas gauge, Check with what Scotty said. It could also be the sending unit connection.
I wouldn't worry too much about that slant 6 motor over heating a little. They are one of the toughest motors out there.
Welcome to the forum and to the Mopar world. Post some pics of your 65 Fury in the new member section.
BobbyWyatt
Apr 9, 2013 09:59 PM
furyous64
Apr 14, 2010 10:38 AM
BigPaddle
Jan 21, 2010 07:04 PM
FuryGC
Oct 30, 2009 12:54 PM
furyaboveall
Oct 21, 2009 03:43 PM
