'68 fury iii disc conversion
Old Sep 11, 2016 | 08:20 PM
Born_Again's Avatar
I'm trying to convert my front brakes from drums to discs. I've found kits all over the internet for A,B, and E body styles but the only one I saw for C body was just the caliper and rotor. I know my body style is very similar to a Dodge Roadrunner and a Roadrunner is B body so I wasn't sure if a B body conversion kit would fit or not, and I'm trying to do my research before I spend that kind of money on the wrong kit.
Old May 31, 2017 | 11:32 AM
lmnlmno's Avatar
I used the SSBC A154 front disc conversion. I got it from Summit which was a few hundred less than SSBC was directly selling it for. The kit was well put together and included just about everything. The only thing aside from the kit that I needed was a tube bender and some adapters for the brake line provided. I just checked Summit to see if they still have it and it looks like it comes sans booster now. Might try calling them after you give it a look-see and see if you can find a kit with booster if that's what you're into.
Old Jun 1, 2017 | 04:07 PM
Born_Again's Avatar
​​​thank you for the information. I looked at the kit and it looks like it's exactly what I need. What vehicle did you use it for??
Old Jun 3, 2017 | 02:04 PM
lmnlmno's Avatar
I used it on a 65 Fury III.
heminate
Aug 18, 2019 03:06 PM
61 Fury
Mar 14, 2016 04:50 PM
Rbaisch
Dec 1, 2008 02:17 AM
mahd
Nov 8, 2008 09:55 PM
BTKBraden
Feb 22, 2007 11:31 AM
