1961 Plymouth Fury drum to disc brake conversion questions
Old Sep 28, 2013 | 12:14 PM
61 Fury's Avatar
Hi, I have looked all through the site but nobody seems to have talked about drum to disc brake conversion on any '61 models. Even on disc brake conversion websites, the retailers all seem to start their kits at '62 and newer. Am I missing something, or are there no kits available for pre-1962 cars/trucks?
Thanks for any light you can shed on this mystery. A caveat...I may not have read every thread on disc brakes here, so maybe I did miss a thread that would help me.
Old Sep 28, 2013 | 12:34 PM
moe7404's Avatar
just a shot in the dark. it might have to do with the rear axle being a tapered shaft on the end. on the chrysler body cars this was used throu 1964. 1965 being the first year for the flanged axle, this is on chrysler body, dodge and ply might be the same years. you should be able to find a flanged axle that will bolt in. iam unfamiliar with the front brakes on your body. a 1965 chrysler has reg bendix brakes.
Old Feb 24, 2016 | 02:01 PM
61 Fury's Avatar
HI, I'm back to this thread I started a few years ago, and I'm still searching for an answer.
I want to convert my front drum brakes to disk brakes on my '61 Plymouth Fury. All kits seem to be for 1962 and newer, so far. I called Wilwood and they advised me to swap my spindles for 1965 Fury spindles and then call them. Can anyone confirm that '65 Fury spindles will fit on my '61? Is this the route I should take? Does anyone have any other suggestions? I was given the option available in the link below. Does anybody have any experience with this alternative? Any opinions on it? Sorry, many questions here, but will appreciate any help you can give. Glenn
https://scarebird.com/index.php?rout...&product_id=54
Old Feb 24, 2016 | 02:15 PM
Sorry Glenn... I got nothing for you on my end...
Old Mar 14, 2016 | 04:50 PM
red67's Avatar
on the Chrysler body 64 was the last year for thread in ball joints. cheap to buy but hell putting them in. 65 went to bolt in ball joints easy to put in but cost a lot more. this is a Chrysler body dont know about the others.
heminate
Aug 18, 2019 03:06 PM
Medix
Nov 3, 2017 07:37 AM
motorcitymopar586
Sep 28, 2013 12:12 PM
Lee Herendeen
Oct 9, 2012 08:34 PM
rookie440
Sep 4, 2010 06:20 PM
