blowers ?
Old Jul 25, 2009 | 07:30 AM
67Polara's Avatar
blowers ?
what do you guys thinkabout putting a blower on a 67 Polara ?
Old Jul 25, 2009 | 07:58 AM
Morrigan_Aria's Avatar
Hell kitten
I want one on my 53 Plymouth sled...lol....on the inline 6 cylinder.
Old Jul 25, 2009 | 09:12 AM
67Polara's Avatar
thad be pretty cool, i'm just having that issue of do i want to keep it stock n classy or go all out on the car.
Old Jul 25, 2009 | 09:40 AM
you have to be sure that your engine can take it
Old Jul 25, 2009 | 10:00 AM
67Polara's Avatar
how would i go about doing that ?
Old Jul 25, 2009 | 04:22 PM
your compression can't be too high
you'd need stronger rods, crank, etc.
Old Jul 26, 2009 | 04:43 AM
With a blower you want to run ~12:1 I heard. Your lower end has a to be beefed up to handle the force along with the valvetrain. Its a lot more work than most people think. What size blower are you looking at?
Old Jul 26, 2009 | 05:51 AM
67Polara's Avatar
i'm not sure what size i dont know to much about cars mechanicly
Old Jul 28, 2009 | 09:10 AM
SMRE's Avatar
Originally Posted by 78D200
With a blower you want to run ~12:1 I heard. Ypu lower end has a to be beefed up to handle the force along with the valvetrain. Its a lot more work than most people think. What size blower are you looking at?
We recommend 8-8.5:1. Some combos can go a bit higher, but some will require intercooling to prevent detonation. Many variables go into determining a combo. What are your goals? I mean are you looking at putting one on for a certain amount of horsepower? Just want one mostly for looks (we get that more often than you would think), or maybe just like the way they sound? I find that if I understand what someone is looking for, we can point them in the right direction a little easier.
Old Jul 28, 2009 | 11:34 AM
What is a higher compression ratio needed for then? I thought it was for blowers.
Old Jul 28, 2009 | 07:19 PM
theomahamoparguy's Avatar
no, just the opposite. More boost-more pressure so you start with low compression. 12:1 compression would blow the heads off the block!
I like the idea of twin turbos. Plenty of room under the hood of that C-body for it.
Old Jul 28, 2009 | 08:47 PM
67Polara's Avatar
how would i go about finding out the compression on my car ?
Old Jul 29, 2009 | 09:10 AM
SMRE's Avatar
You might be thinking of NOS or something else. You don't need the compression for a blower for sure. You can get away with a little more than 8.5:1 in many cases. It really depends on a number of factors.
Old Jul 29, 2009 | 03:10 PM
you always want lower compression with a blower
if not, you'll literally melt the pistons
Old Jul 30, 2009 | 04:34 PM
67Polara's Avatar
ok i think i'll just fab a hood scoop then lol
Old Jul 30, 2009 | 06:15 PM
a compression test should do it
Old Jul 30, 2009 | 07:14 PM
67Polara's Avatar
well if it wasnt right i wouldnt kno where to go from there n i dont want to take the chance of messing up the car, i need it every day she's my daily driver so, but more importantly i dont want to hurt the car in any way.
Old Jul 31, 2009 | 03:46 PM
good choice
since its your DD, dont do anything radical to it yet
Old Jul 31, 2009 | 07:00 PM
67Polara's Avatar
yeah i think that would be a wise choice there, thanks =)
Old Jul 31, 2009 | 07:49 PM
no problem
Old Aug 22, 2009 | 09:38 AM
68Fury68's Avatar
Junior Member
LOLi thought about TT my 383... i think im just going to go with some new heads intake new carb and cams for now..... then this winter mabye new crank rods pistons...imma play it off as "Hey babe, i need to paint the engine block...and in order to do this....i need to take it apart" and alas ILL forget where i laid CERTian goodies...and need...newer ones LOL
but in reality TT and SC been on my mind, but i dont know what the 727 is ca[pable of handling as its an automatic This will be my first AUTOMATIC car im tackling and older car at that so im a little dumb about autos....
i just had the tranny rebuilt though,So i dont know if TT or ST or SC is an option? id be doing all the grunt work if its turbo i go with, im not looking for nothing crazy just something different,Thats if these trannys are capable of handling this?"
spec 68 furyIII 4 door
727 tranny (recently rebuilt)
