need a little help
Old Jun 9, 2010 | 05:07 AM
Ryansfury66's Avatar
Junior Member
need a little help
Im needed to upgrade my altenator, as my factory one cant handle my power needs. I think ive found one, but how can i tell if i have a round or squareback one? Thanks
Old Jun 9, 2010 | 05:17 AM
1966sportfury's Avatar
A.K.A Bob Dodge
this is a square back alt. see on the back how it has the raised square area. round back dosent have that,
Old Jun 9, 2010 | 05:25 AM
sweeperking's Avatar
I'm not sure what you mean by "round" and "square back" but mopar alternaters come in differnt amperage ratings 35, 45, and 60 amps for stock depending on engine size and what toys you want to power. I know they also make 80 and 100amps that will work also. I believe these ratings are stamped on the case just make sure to check if you got one or two field terminals and make sure the new one has the same
Old Jun 9, 2010 | 05:28 AM
I know what you mean here just never heard of alternaters identified this way
Old Jun 9, 2010 | 05:37 AM
A.K.A Bob Dodge
took a wile but this is a round back.. i posted the pics for ryansfury66 he seemed not to know the diff so pics should help
Old Jun 9, 2010 | 05:41 AM
A.K.A Bob Dodge
realy? you never heard them called round or square backs? thats how you would order rebuild kits "85 amp square back." or whatever amp.
Old Jun 9, 2010 | 06:01 AM
Junior Member
thanks for the quick replys. Im not sure what size mine is but is acts very tired, just with headlights on at night the lights slightly flicker to the rpms of the car. I will try to post some pics up when i can.
Old Jun 9, 2010 | 06:02 AM
Never heard them called that either. I have heard them labeled based on wire hook up though.
What are you trying to power?
Old Jun 9, 2010 | 06:08 AM
A.K.A Bob Dodge
when you go to rebuild them thats how you would call them, at least around here. its common talk.
Old Jun 9, 2010 | 06:13 AM
So...by looking at the pictures it looks like the squarebacks have the two field terminals and the roundbacks have the single field terminal,
Old Jun 10, 2010 | 07:21 PM
Junior Member
I put a sound system in it a few years back. its around a 600 watt amp. I thought my headlights were just bad, but changed them out last year, and still had problem. Another question. Has anyone put led bulbs in replacement of the factory bulbs?? Would like to change out all the bulbs.
Old Jun 10, 2010 | 07:47 PM
If your talking headlights I have never heard of this (then again I never heard of square/round back either) guess I got to get out more but leds would take alot less power and be a he11 of a lot brighter
Old Jun 10, 2010 | 07:50 PM
Junior Member
im talking bulbs such as as rear lights turn signals. has anyone replaced their dash lights before? Got a few that are burnt out.
Old Jun 11, 2010 | 08:22 PM
Junior Member
anyone know where i can get some brighter headlights??
Old Jun 11, 2010 | 11:24 PM
A.K.A Bob Dodge
what do you have incandescent? any place like napa, AutoZone. should have halogen
Old Jun 12, 2010 | 06:20 AM
Dash lights are easy, you got to reach up behind the dash and feel for what feels like a plug. This is the socket that the dash light plugs into. There maybe a few back there I dont know how many you have. AnyWho, rotate that socket 1/4 turn CCW and it comes right out. Replace with a #194 bulb.
As far as the headlights go there is brighter light out there thats even brighter than a halogen. I cant think off hand what its called but its a blue light. Been meaning to look into it myself for the Ram.
Last edited by sweeperking; Jun 12, 2010 at 06:22 AM. Reason: spelling corrections
Old Jun 12, 2010 | 10:32 AM
A.K.A Bob Dodge
xenon i think that what your talkin about
Old Jun 12, 2010 | 06:29 PM
Junior Member
looked at my alt today, and im thinking its a round back. Should i got normal hookup or one wire since im getting a higher amp alt?
Old Jun 14, 2010 | 12:39 PM
Junior Member
anyone?
Old Jun 14, 2010 | 03:40 PM
I ran a 120 amp Power Master alt in my J10 when I had it. Single wire hook up, and replaced the amp meter that I had (aftermarket) with a volt meter.
Are your headlights/light dimming when the bass hits?
Old Jun 14, 2010 | 04:43 PM
Junior Member
yes they do.. headlights even flicker and are kinda dim when car is running without stero on
Old Jun 14, 2010 | 07:25 PM
Junior Member
so if i get a single wire hookup, what do i do with the extra wires? and will my charge meter still work?
Old Jun 15, 2010 | 03:45 AM
I taped up the connector, ran a wire to the battery and the other to the volt meter.
They come wth pretty detailed instructions. You should probably call up a place like Power Master and tell them what you have. They can probably tell you exactly what to get.
I'd also look into getting a capacitor for your audio. It will help to keep your lights from dimming. Just shop around as they are mostly all the same but can be had for cheap.
http://www.crutchfield.com/p_211PSC4...1.html?tp=2614
Old Jun 15, 2010 | 09:19 AM
  #24
A.K.A Bob Dodge
older computers used to use 1/2 farad and you can usually find them for 5 bucks..1/2 a farad is good to 500 watts
Old Jun 16, 2010 | 03:11 AM
  #25
He's running a 600 watt audio system so a 1 farad capasitor would be perfect for it. That is what I am actually going to be running in my truck and I have a Rockford T600-2 amp pushing two P3 10" shallow subs in sealed boxes.
JRmopar24
Apr 27, 2015 10:39 AM
Hibred
Nov 5, 2013 08:07 AM
Duster360
Mar 5, 2012 07:13 PM
sporttruckr
Mar 24, 2011 09:17 AM
timmymacnj
Apr 9, 2010 07:44 AM
