New 67 Fury Owner - Few Questions
Old Oct 18, 2009 | 06:23 PM
furyaboveall's Avatar
I've done a few searches but am having problems finding the engine oil and transmission fluid capacities for a 383 4bbl Commando V8 325hp. Any help would be appreciated.
Old Oct 18, 2009 | 07:29 PM
MrOldart2U's Avatar
Engine oil 5 qts with filter change, 4 without. Trans filter change capacities would be about 5 qts. If tranny is new, rebuilt, whatever with new converter it will hold 10-12 qts of fluid. Hope that helps....
Old Oct 20, 2009 | 06:08 PM
Thanks, it does. What kind of engine and trans oil should I put in the car? Do you know oil filter and/or trans filter part number?
Old Oct 21, 2009 | 01:06 AM
grissomracing's Avatar
Member
I can't help with part numbers...but, I'll give advice on the fluids. On the tranny fluid, i would use ATF+4, which is far superior to regular mercon/dextron fluid. It has friction modifiers in it that regular dextron does not, which equals better shifts and longer life. On the engine oil, I would use any quality name brand oil. I personally use Valvoline 10w-30. Hope this helped
Old Oct 21, 2009 | 11:45 AM
sgp7679's Avatar
i use and recommend castrol gtx
Old Oct 21, 2009 | 03:43 PM
i would recommend rotella T
read this: https://moparforums.com/forums/f62/o...-engines-2333/
moparboy
May 27, 2011 08:50 PM
BigPaddle
Jan 21, 2010 07:04 PM
CoogarXR
Oct 15, 2009 03:19 AM
TheKneeBita
Sep 6, 2008 12:52 AM
team39763
Jan 20, 2008 05:42 AM
