Putting 440 in my 68 fury what posi rear end?
Old Jul 16, 2012 | 02:31 PM
68 Fury's Avatar
I am going to put a 440 in my 68 fury. I am wondering what the best posi rear endwould be to use with the least amount of cost and work.
Old Jul 16, 2012 | 02:48 PM
Your 68 Fury should have an 8 3/4 rear end. So it would be very easy to install a sure grip rear carrier.
The center section is removable
Old Jul 16, 2012 | 02:56 PM
68 Fury's Avatar
Rear end
Will any center section bolt in? How about the axle shafts does that change? Like will a 489 742 fit?
Old Jan 17, 2013 | 11:53 AM
rockerarm's Avatar
8 3/4
All 8 3/4's will interchange as well as the axles as long as they are the correct length, some housings are wider then others.
OH..... by the way Mopars have "SURE GRIPS".... not posi traction.
Best all around ratio...... 3:23
Old Feb 19, 2013 | 06:05 PM
jacilynn_s's Avatar
uhm there is two types that go in that axle. Auburn or clutch type. Depending on which you will also need the pins to go on the end of the axles so it's a valid question.
Posi-trac is a general motor term. sure grip is the chrysler dana term. As you can see some people take offense at it. You can also use limited slip if you wish though even that some are ornary about.
Old Feb 20, 2013 | 06:01 PM
moe7404's Avatar
if your 68 was a org 383 2bdl the carb parts are not made to fit a 4 bdl. the 4bdl connections to the cables ect are more forward and to the left than 2 bdl parts.
dakota7695
Feb 21, 2014 07:50 AM
maynardc69
Jul 27, 2013 12:15 PM
oldiebutgoodie
Oct 12, 2012 04:03 PM
Muswagon
Nov 18, 2009 07:47 AM
stanhope55
Mar 19, 2009 05:35 PM
