Timing issue or cam timing issue?
Old Sep 1, 2014 | 11:53 AM
  #61
19newport72's Avatar
I will have to post a little walk around video or pictures of the car so you can all see my never ending project now. ill try to get a nice acceleration video also. It had no problem burrying the 120 on the dash but that speedo isnt synchronized to the transmission either so i dont know how fast i was really going. Its finally complete!!!!!!!!!!!!!!!!! Thanks everyone and i know someone recomened to chain the engine down on here and i should have done that a whole ago now i have a dent in my header but i will be installing a chain soon aswell!!!!! Thanks again! I'll probably post a video on a separate forum or pictures of the car just to share.
Old Sep 1, 2014 | 12:06 PM
  #62
You Sir have just earned a Non Refundable, Non Transferable ATTA BOY!
Old Sep 1, 2014 | 05:40 PM
  #63
Originally Posted by 19newport72
ok heres what was wrong. the timing gear on the crank was set to zero which was correct. BUT! he did not line the dots up correctly. instead of using the dot on the crank pulley he used the zero mark for the crank timing so the cam pulley was roughly lined up with R4. that was about 5 teeth behind the actual timing mark that should have been used on the crank gear. the car runs amazing now
Well gee LOL what'd (I tried) to tell you
VERY glad you found this finally
Old Sep 1, 2014 | 06:41 PM
  #64
demetri's Avatar
Glad your engine does not stall any more. But it is hard to believe that an error in the cam timing can really cause the engine to stall completely.
If your original gear was 2.76, and the speedo was accurate at that time, and if you have the same tire size, your 120 indicated should be around 90.
Old Mar 27, 2024 | 01:40 PM
  #65
justin wilson's Avatar
timing
i have a 1974 dodge dart with new freshly rebuilt motor i cant find any timing info
Old Mar 27, 2024 | 06:44 PM
  #66
Your welcome to start your own thread, please ask your questions and post information about motor transmission etc so we can help.
Sjzdx
20
Jan 8, 2022 09:03 PM
Joel Carvalho
Oct 8, 2015 12:26 PM
oldiebutgoodie
21
Sep 30, 2013 04:29 PM
Kyle Monroe
Jul 17, 2013 07:34 AM
Gorts 5th
Dec 19, 2012 04:52 PM
