Upper Ball Joints '68 Town and Country
Old Oct 25, 2011 | 09:45 AM
EdR's Avatar
EdR
I'm having trouble locating upper ball joints for Le Barge. Any suggestions? Thanks, Ed
'68 Chrysler Town & Country
Sovereign Gold
383 2bbl.
Attached Thumbnails Upper Ball Joints '68 Town and Country-1968-wagon-rr-qtr.jpg
Old Oct 25, 2011 | 01:59 PM
rexus31's Avatar
Mid Canada Suspension.
Old Oct 25, 2011 | 02:22 PM
I don't know where you are , just a quick look. AutoZone has them, I would look for Moog ? brand though...
It does require a special socket for replacement..
Old Oct 25, 2011 | 02:52 PM
RockAuto.com.
Old Oct 29, 2011 | 04:00 AM
EdR's Avatar
EdR
Drat! I need the lowers as well. They're harder to find it appears.
Old Oct 29, 2011 | 07:21 AM
I got them for my 68 Dart at O'Rielly's.
Old Oct 29, 2011 | 08:38 AM
rexus31's Avatar
Mid Canada Suspension. I got the entire front end kit (Moog) for my '65 300 from them. I doubt you will find the lowers at a parts store. They are different than those on A Bodies.
Old Oct 30, 2011 | 03:32 AM
EdR's Avatar
EdR
Lower Ball Joints
Thanks, I'll call them tomorrow.
Old Nov 1, 2011 | 05:29 PM
shovel55's Avatar
Ball Joints
Hi Ed sent you a PM on the ball joints
Old Nov 11, 2011 | 02:04 PM
bboogieart's Avatar
Nice wagon Ed,
Let me know if you find this tool or if anyone knows where to find them. I have had no luck. They are specific to the c-bodies, and from what I read some 70's light trucks. Every time I think i've found one it turns out to be the wrong size.
Old Nov 11, 2011 | 07:12 PM
Originally Posted by bboogieart
Nice wagon Ed,
If it is the big ball joint then Mancini racing has them...I bought one.
Old Nov 11, 2011 | 08:28 PM
shovel55's Avatar
Ball Joints
I do believe the lowers are the whole assembly I believe
Old Nov 12, 2011 | 02:24 PM
The top ones screw in a very large cresent wrench with a very large cheater bar or that high dollar ball joint socket is required.
Old Nov 13, 2011 | 02:28 PM
bboogieart's Avatar
bremereric
Thanx I will have to measue to make sure. I do believe that the a and b bodies have different sizes as well but could be wrong. I will see what mancini has. Did you use yours for a c body? They are specific, as I mentioned.
shovel55
Yes the lowers are a complete cast iron unit that bolts to the spindle through the backing with the two lower bolts, and also connects to the tie rod end. Going to have to unload the torsion bar or put the jack under the spindle so it does not come flying apart, when un bolted. Lot's of tension and potential for injury. Be careful.
Old Nov 13, 2011 | 02:48 PM
bboogieart's Avatar
herer is a picture of the lower ball joint hanging down underneith the spindle. You won't need to remove the backing plate, I just did cause I was cleaning and painting. You can see how the lower joint will attach. Taking this apart can be dangerous but common sence and a little for thought will go a long way. I had the car supported by the frame and used the jack to lift the lower control arm and take the tension off it.
Attached Thumbnails Upper Ball Joints '68 Town and Country-a2brakes5-2-11.jpg
Old Nov 14, 2011 | 06:31 PM
shovel55's Avatar
Ball Joints
I do have the two lower ones if anyone is looking for a set.They are Moog K7003 and K7005 new in the box.These are a special order nowadays.
Old Nov 14, 2011 | 08:37 PM
bremereric
shovel55
Here's the link to the Mancini Racing front end tools...small and big upper ball joint sockets. Measure yours to comfirm which one is for you. I used mine on my Aspen and mine where the larger ball joints.
http://chucker54.stores.yahoo.net/frsuto.html
Old Nov 16, 2011 | 06:13 PM
bboogieart's Avatar
Thanx for the link. I do beleive mine are 1.951 but have not checked them yet. I have a cheap mike but am not familiar with converting inches to what ever that 1.951 is.
bundu
Feb 11, 2015 01:52 PM
Mopar17
Jan 3, 2013 06:55 AM
bemill
Apr 5, 2012 06:39 AM
phil111260
Feb 3, 2011 05:17 PM
gihuff
Jun 26, 2009 04:15 PM
