&0 AAR Cuda Exhaust headers & heads
Old Dec 17, 2014 | 12:58 PM
CudaBob's Avatar
Newbie, 70 AAR Cuda with correct heads, headers on it are sooo rusty you can poke your finger through, are the heads exhaust ports the same as other 304 heads? looking to find a replace set of headers?
thanks for your help
Old Dec 17, 2014 | 03:09 PM
John Van's Avatar
I do believe all la small blocks have the same exhaust ports locations, I recommend the Heddman Elite headers, as they have thicker flanges and tubes.
john
Old Dec 17, 2014 | 04:33 PM
moe7404's Avatar
BIG HINT: ALL WAYS use anti-seize compound on ALL bolt threads in ext systems. on cast iron manifolds. tighten bolts to 70-80% of full torque at first. then after 5-7 full heat cycles take to full torque. but check with the header experts for doing headers. one exception is slant 6 manifold. its torque processe is much diff.
Old Dec 17, 2014 | 08:38 PM
There are exceptions but 98% are the same W2's are different
aarcuda7954
Sep 7, 2014 06:58 PM
408duster
Jun 9, 2011 11:28 PM
rabys
Sep 14, 2008 04:05 PM
rabys
Mar 22, 2008 11:37 AM
rabys
Nov 25, 2006 08:46 PM
