1974 360 la engine
Old Jan 11, 2011 | 03:33 PM
sammy9015's Avatar
1974 360 la engine
I have a 74 360 la engine .030 over, 4bbl edelbrock, headers,weiand alum. intake
J heads with 2.02 and 1.60 valves and stock cam.How much ball park Hp is is and what can I do at reasonable cost to improve it? IN 73 challenger with 727 trans.
Old Jan 11, 2011 | 06:55 PM
1966sportfury's Avatar
A.K.A Bob Dodge
its could be 15-25 more than stock hp, depending on the compression
raise the compression. a bit more cam. massage the heads.
Old Jan 12, 2011 | 03:06 AM
The right cam can add 25-40 hp easy if not more.
I would call up comp cams or crane cams and give them the the specs on what you have. They will be able to match a cam to your motor and needs perfectly. I think it's Comp Cam that actually has an online spec sheet that you fill out and it will spit out the right cam too.
randy8
Jul 30, 2014 09:24 AM
tjackson2011
Mar 3, 2014 11:01 AM
vrossi
Mar 27, 2013 08:24 PM
keith811
Jan 13, 2011 10:43 AM
choelzer
Feb 29, 2008 03:00 AM
