8 3/4 Rear end with Grinding sound
Old Aug 19, 2021 | 06:41 PM
Cuda Man's Avatar
Question 8 3/4 Rear end with Grinding sound
My 74 cuda has a 8 3/4 rear end. I have owned the car for about 1000 miles with no issues. Now it is starting to make noise, from the right rear I believe. Every time I turn/swerve slightly left and put pressure on the right side is seems to growl. I first checked the adjustment nut on the axle and it was way loose and the previous owner did not lock it into place, so I assume it had slowly backed out some and gave me the extra play left to right. I tightened the lock nut to about 8 thousands play and did a test drive. The axle still is making noise and the axle hub on the right side is hot to the touch. I pulled the axle out and the bearing seems to be ok. Could it still be the bearing? Or is there something I'm missing? The person I bought the car from has reworked most of the car, so I am surprised I am even having an issue. Thanks
Old Aug 20, 2021 | 07:17 AM
Could be a Axle Bearing going bad?
Old Aug 21, 2021 | 07:32 AM
Cuda Man's Avatar
The axle bearing feels fine. The break linings are new and look like new. The driver's side hub area was cool to the touch, so I continue to blame something on the right side of the car. It almopst has to be the bearing, even though it seems to be ok. Thanks
Old Aug 21, 2021 | 08:59 AM
Cuda Man's Avatar
Also, if the bearings are just pressed onto the axle from the splined end, what keeps the axle from not just working it's way out while driving. I can see the bolted flange keeping the outer race in place but nothing to keep the axle from moving outward. Thanks
Old Aug 22, 2021 | 05:46 AM
Press on Retainer usually >>>> unless it has been converted to something else..
70newport
Jun 5, 2013 06:23 PM
68lover
May 5, 2010 08:30 AM
samuelcosmo76
Jan 9, 2010 07:43 AM
fishpwr
Oct 3, 2009 09:15 AM
mahd
Nov 1, 2008 07:50 AM
