Carter Carbs
Old Dec 24, 2013 | 12:35 AM
Nikko_01's Avatar
Carter Carbs
Hi everybody! I need help finding a part for my Carter 2 barrel carburetor. The fast idle cam is broken. Is this a part i can order by itself or is it in a kit? I haven't been able to find one anywhere.
Old Dec 24, 2013 | 03:52 PM
moe7404's Avatar
unlikely you can order just the part. that carb was made for very very very many years. finding a good carb should be easy and cheap. if it looks like i fits it WILL. HINT: the float level is 1/4 , with casting setting top up like it would be on the engine, with lid off. it NEVER is different. the carb has 3 castings. on the rear is 2 screws that go from the top casting into the bottom casting. be sure the casting faces are flat, and do not over tighten the screws to tight that will warp the castings. just just two fingers on the screwdriver.
Old Dec 24, 2013 | 04:04 PM
Nikko_01's Avatar
thank you! I think i am just going to order a new carb and start fresh anyway. I have a long way to go and i just want it running and driving. Thanks again for the help!
BruceB
Aug 17, 2013 05:21 PM
Dizzle
Sep 16, 2010 09:13 AM
jdcarnathan
Aug 14, 2010 12:53 PM
Tiretrack
Jul 12, 2010 02:52 PM
