Lighting issue
Old May 1, 2012 | 06:28 PM
jsacks1981's Avatar
Lighting issue
I have a 73 challenger and the tail lights and dash lights stay on always even when car is off... I cant understand why or find the reason why???
Old May 2, 2012 | 03:34 AM
Mr.4spd's Avatar
I could guess, but you'd be better off purchasing a factory service manual from Year One and a 12 volt tester. The manual has wiring diagrams. My guess is that a previous owner did something creative to "fix" another problem.
Old May 2, 2012 | 08:28 AM
I agree, buy a shop manual. You can get either paper reprints or "on CD" from several places, and ebay
One check you can make quickly would check for a short in the rear harness
I'm not very familiar with E bodies, but normally, the rear harness comes up forward, under the sill plate, and has a connector up in the left kick panel or maybe even above as it comes up over the top, which connects to the dash
One hot wire in this harness is the dome light. So if the harness has a short between the tail circuit and the dome circuit, the tail lamps would light
So try pulling some fuses and see what kills power to what.
You also could try removing the kick panel and separating the connector. Obviously, this will kill the TAIL lamps, but if this action also kills the DASH lights, then you know that harness has a problem
Other than that, check out the light switch.
You can get pretty basic wiring diagrams here
(A quick look, though, shows this to be incomplete at the light switch)
http://www.mymopar.com/downloads/1973/73ChallengerA.JPG
http://www.mymopar.com/downloads/1973/73ChallengerB.JPG
which came from here
One thing you need to keep in mind is that Mopar light switches have TWO separate power sources
ONLY the headlights power is supplied UNfused power from the "in harness splice" in the ammeter circuit directly to the headlight switch, which has a built in breaker
The tail/ park and dash light power is supplied FROM the tail fuse
BUT the OUTPUT of the dimmer control going TO the dash lights first goes through a fuse ONLY for the panel lights. On diagram "A" I posted, this is the top right fuse, the tan is power coming FROM the dash dimmer, and orange goes OUT to all the dimmer controlled instrument lamps.
Old May 2, 2012 | 07:07 PM
jsacks1981's Avatar
Thanks so much for the info guys... I am thinking about rewiring the whole car anyone know where i can get a full wiring harness kit??? Would really like a oem one
Old May 2, 2012 | 07:15 PM
Mr.4spd's Avatar
Year One has 'em. I'd try testing out what you've got first, though. Get the FSM. Lots cheaper than all new wiring harnesses.
Old May 2, 2012 | 07:20 PM
jsacks1981's Avatar
where can i get an FSM
Old May 3, 2012 | 07:18 PM
Mr.4spd's Avatar
I bought my factory service manual from Year One. Amazon has them new in stock, as well as some vendors on eBay.
70newport
Jun 10, 2020 08:34 AM
MilesP
Oct 19, 2013 10:00 PM
poisonr98
Aug 19, 2013 10:09 AM
samuelcosmo76
Jan 22, 2010 07:53 AM
thumpn
Feb 13, 2007 11:03 AM
