serial number
Old May 2, 2012 | 05:23 PM
gregsgs@yahoo.com's Avatar
serial number
hi every one iam thinking of getting a 70 cuda and from all the reading on the sites the serial numger should start with BS this one on the bottom left starts with E55 but has BS23 in the line any help with this.
thanks
Old May 3, 2012 | 02:52 AM
mr340's Avatar
The VIN will be the last 13 digits on the bottom line of the fender tag.
Old May 3, 2012 | 11:04 AM
Why would you not just read the VIN off the dash where it should be?
Old May 3, 2012 | 03:21 PM
mr340's Avatar
I think he is trying to decode the fender tag.
Old May 3, 2012 | 06:23 PM
hi guys yes iam decoding the plate i can read everything including the bs23, but its the 4-5 set of numbers. let me no thanks.
Old May 4, 2012 | 03:12 AM
mr340's Avatar
Look here for info on decoding the VIN and fender tag. At 37k I would want to be sure that the car is legit!
Old May 4, 2012 | 08:34 AM
The point I'm trying to make, is that fender tags can be easily removed and replaced. When I used to hang out at Moparts I got into a HECK of an argument over there with a couple of guys who "collect" them.
If this car has been hacked up or "rebodied", anybodies guess. I would do a LOT more than look at the fender tag. There are other SN's on other parts of the car. I'd compare them to the dash VIN, and the fender tag, and go from there. For me, the fender tag is the LAST thing I'd trust as "documentation."
Old May 4, 2012 | 02:41 PM
MrOldart2U's Avatar
Well THAT takes care of THAT... I would def make sure its legit...
Old May 6, 2012 | 06:04 PM
Someone said that there are other places to check the serial numbers. can you tll me were that is. the block has a serial number on the right side he said its a date code engine meaning matching number any help would be GREAT
Attached Thumbnails serial number-1970-plymouth-cuda-block-.jpg   serial number-1970-plymouth-cuda-main.jpg
Old May 7, 2012 | 03:24 AM
mr340's Avatar
Date code is not necessarily numbers matching, it just means that the manufacture date is close the the date the car was built. Other VIN locations are the trunk rail under the seal (usually on the drivers side, and also on the radiator support. I would also look at the block for the correct VIN. The number you show is a casting number not a VIN or date code.
ngc414
Feb 4, 2021 07:27 PM
malcolm2
Oct 6, 2011 03:04 PM
66Chrysler300
Aug 4, 2011 07:01 PM
56plaza
Sep 9, 2010 06:57 PM
glennmccann
Jan 3, 2008 11:04 AM
