Unisteer rack & pinion
Old Jul 10, 2018 | 07:19 AM
hemiaction's Avatar
Red face Unisteer rack & pinion
Have anybody installed a rack & pinion steering from Unisteer ? and have trouble with the 90 degree conection between steeringshaft and the rack from unisteer , there are used 2 universal joints , they have too take 45 degree each , and you not get any smooth steering feeling , anybody have an idea what too do for too get this right ? , unisteer dont know and say this will work , but it does NOT.
Thanks Lars
Old Jul 10, 2018 | 10:11 AM
I don't have experience with this one but I have with others. The steering shaft has to be fazed like a drive shaft, if you have even one joint off you will feel it.......
Old Jul 10, 2018 | 07:10 PM
Photo might help us address the problem....
Also what are you trying to install it in?
Old Mar 30, 2020 | 05:40 PM
Jim121's Avatar
Thanks Lars
Old Mar 30, 2020 | 05:46 PM
Jim121's Avatar
Jim121
Did you get your steering shaft problems worked out?? How do you rate the Unisteer Rack and Pinion steering set up now that you have used it for a while?? I’m seriously considering converting my 70 Challenger steering to the Unisteer system. In order to have better room in the engine bay as well have better steering and less weight. I would appreciate your input please.
Old Mar 30, 2020 | 11:53 PM
hemiaction's Avatar
Hello. I have done some testing , have now a double universal joint and a single joint , and it is about 90 % ok. but it could be better , i am looking for other options , just try too find a 90 degree steering gear, in a small compact size , On older Toyota Hiace With right side steering , there was used a 90 degree gear that can be used , so right now i am looking too get one of these and install it on the rack , and get rid of the universal joint setup , thats my idea, if you buy the rack and pinion from
unisteer , and follow their instruction and mounting i think you will be disapointed , we have 2 Challengers here With the unisteer setup and that is not recomended , not at all.
Thanks Lars
Old Mar 31, 2020 | 06:45 AM
Jim121's Avatar
Unisteer
Did you get my Reply from this AM?????
greasemonkey
Nov 15, 2017 10:13 AM
roger.bell
Jul 2, 2015 10:20 AM
floridamtbiker9
May 5, 2013 08:00 AM
Zoomer59
Feb 13, 2013 06:38 PM
Leem
Oct 29, 2011 07:13 PM
