Timing for a 318 in a 78 Aspen
Old Sep 7, 2021 | 08:52 AM
RockStar1776's Avatar
Does anybody know how many degrees off from TDC I should adjust to when timing the 318 motor in my '78 Aspen R/T?
***If it makes a difference- I have a mechanical distributor that is not original equipment.
Old Sep 7, 2021 | 05:27 PM
If it's stock I'd start about 10° before TDC, if it has a performance cam it could be up to 20°.
Old Sep 10, 2021 | 04:42 PM
Agreed...
Old Nov 3, 2021 | 08:05 PM
I have a new set of points sitting around, so I figure I might as well put 'em in and change the condenser while I'm at it. Any idea what kind of gap I should have on them? Also, what kind of dwell reading should I get when it's all said and done? The motor is a 318 with a mechanical ignition system.
Old Nov 4, 2021 | 05:54 AM
0.019 Gap
29-31 Dwell
Old Nov 4, 2021 | 11:39 AM
Archer's Avatar
RS -
You have a 78 Aspen with points???
Why???
It should have an electronic ignition.
As far as timing, modifications and age factor in. While 10* is a std advance, your ear or a tach/vac gauge gets the final vote.
Old Nov 4, 2021 | 11:44 AM
Originally Posted by Archer
RS -
Why???
Archer-
The first owner of the car was a complete idiot. He removed the electronic ignition and lean burn system and put in a mechanical ignition. I could install an electronic system for ~$250, but I can simply maintain the mechanical one for ~$25. My wallet likes the second option better.
Old Nov 4, 2021 | 01:00 PM
Originally Posted by RockStar1776
Archer-
The points are just simpler to install when replacing a leanburns twenty five wires.
Old Nov 4, 2021 | 03:13 PM
Archer's Avatar
RS -
Understood, but the electronic ignition is basically a fire and forget.
Most of the kits I've seen were into $150-$190 range.
Not having to play with points, dwell, etc is worth the price of admission, for me anyway.
Just a thought.
Old Nov 4, 2021 | 04:56 PM
I agree I would put a conversion kit in it also.
Old Nov 5, 2021 | 06:41 AM
Iowan,
What do you think of this kit from pertronix (https://pertronixbrands.com/products...31797276409892) paired with one of their "flame thrower III" coils?
Old Nov 5, 2021 | 07:47 AM
I'm not a fan of pertronix...
Old Nov 5, 2021 | 07:50 AM
Do you have any specific ancedote as to why you don't like them?
Old Nov 5, 2021 | 07:51 AM
Archer's Avatar
RS -
Just get the Mopar kit or one of the knock-offs from Summit or JEGS.
Basic KISS principle.
Old Nov 5, 2021 | 10:28 AM
just get the mopar kit!!!
I've seen too many times over the last ten years when pertronix was a problem....
Old Nov 11, 2021 | 10:52 AM
Lostviking's Avatar
You can put the stock reluctor and pick up on the mechanical points plate. That exactly how we upgraded in the late 70's. Then just buy the matching electronic control unit and hook up four wires. I don't know why anyone buy's a "kit".
Shaunjfrey
May 29, 2021 01:34 PM
GoGoMacho
Jun 30, 2020 10:35 AM
kimrpaige
Dec 30, 2013 06:07 PM
mirada82
Mar 14, 2012 09:13 PM
dynahd
Aug 8, 2011 03:26 PM
