1950 Chrysler Windsor engine pull
Old Sep 21, 2016 | 10:01 AM
DLD's Avatar
DLD
Is it better to pull the engine alone, or the entire engine/transmission as a unit?
Thanks,
DLD
Old Sep 21, 2016 | 11:05 AM
Thanks,
DLD
Is there a reason the trans has to come out?
or are you lazy, I'm LAZY and would try it.
Old Sep 21, 2016 | 11:37 AM
DLD's Avatar
DLD
As far as I know the trans does not need to come out. The engine is stuck and won't turn over. It's been sitting for many years. I'm willing to risk it not needing to come out, I just wasn't sure if there was a reason NOT to pull the engine alone.
Old Sep 21, 2016 | 11:41 AM
NOPE!
Old Jun 4, 2017 | 09:48 PM
DLD's Avatar
DLD
Turns out the transmission has to come off, the engine and bell housing come out together. Wasn't too bad. Turns out it spun the #6 rod bearing. Crank has been turned .010 under, and the rod re-sized. Still need to bore the block for new pistons, and I'm working on getting the water tube out, it's being a bugger! Replaced all the exhaust valve guides, the intake guides were in remarkably good shape, well within tolerances.
Old Jul 2, 2017 | 01:55 PM
DLD's Avatar
DLD
I got the water distribution tube out today! All in one piece! It only took about three months of tinkering, sprayingPB Blaster in it and driving a piece of 1/8 x 1 steel into it and pulling it out repeatedly! I was shocked it came out in one piece, saves me a lot of trouble. If I had any way of telling the condition before pulling it I could have left it in.
Old Jul 2, 2017 | 08:19 PM
Cool.... Thanks for the Up Date.. Hope its coming along nicely?
Old Jul 3, 2017 | 07:04 AM
DLD's Avatar
DLD
Slowly.....hoping to pick up a little momentum now that the tube is out.
Old Jul 3, 2017 | 02:12 PM
Keep us posted.....
Old Jul 3, 2017 | 03:34 PM
DLD's Avatar
DLD
I need to figure out how to post photos. :-/
Old Jul 3, 2017 | 07:11 PM
https://moparforums.com/forums/f4/po...pictures-2128/
Old Jul 5, 2017 | 06:58 AM
DLD's Avatar
DLD
Thanks, I'll give it a try!
Old Jul 5, 2017 | 07:01 AM
DLD's Avatar
DLD
Let's see if this worked:
Attached Thumbnails 1950 Chrysler Windsor engine pull-1950-chrysler-small-photo.jpg
DLD's Avatar
DLD
OK, so now I've got it!
Old Jul 5, 2017 | 07:09 AM
DLD's Avatar
DLD
Here's the water distribution tube, fortunately it came out in one piece!
Old Jul 5, 2017 | 10:11 AM
Good Job.... Nice looking ride...
Old Jul 5, 2017 | 02:44 PM
Nice car, put a late Hemi in it!
Old Jul 5, 2017 | 02:47 PM
Oooooooooooo.... I like that Idea....
Old Jul 8, 2017 | 09:21 AM
Keithb7's Avatar
I highly recommend you go to this very active, vintage mopar site. Its an excellent source of help.
http://p15-d24.com/forum/4-p15-d24-forum/
Thanks,
DLD
Old Jul 8, 2017 | 02:51 PM
Good answer because if I owned it the body would not mach the motor transmission, rear axle, front suspension under it!!!!!!!!
Old Jul 8, 2017 | 02:57 PM
Late gene 3 hemi........go for it....
Frogprince
Oct 3, 2013 06:48 PM
Daniel Ramos
Aug 29, 2013 06:57 AM
treys
Jun 13, 2013 02:01 PM
lgad
Jul 25, 2011 08:06 AM
redhearts
May 5, 2011 01:05 PM
