1960 383 Core Plug issue "HELP!!!!"
Old Mar 24, 2019 | 02:20 PM
cjbennett411's Avatar
Hi looking for some advice on what to do with a cracked core plug sealing ridge. I Have done so much work to this block and worried it may be a total loss. It has shallow core plugs so I'm concerned it will leak when engine is assembled. Any advice would be greatly appreciated. I have attached two pics one with a good plug and one that is botched. Thinking of maybe grinding down a newer style plug to the shallow depth.
Old Mar 24, 2019 | 07:22 PM
Can you tap it and tread a plug in? Otherwise use red LockTight on it, I've never had to do it but I've heard it works.
Old Mar 25, 2019 | 10:07 AM
Hi Iowan, After some additional research I went ahead and purchased a new core plug kit and decided to go the loctite route, I found loctite 450 that seems to be specifically designed for core plugs. Going to give that a try but will be months before I find out if it leaks or not. Starting to assemble the engine after I perform a final block wash, install plugs and so on. Thanks for the reply!
cjbennett411
Mar 24, 2018 04:28 PM
a.johansson84
Jun 12, 2014 04:50 PM
Kowalenko93
26
Oct 18, 2013 12:14 PM
69POLARA383
Sep 24, 2010 10:36 AM
Commando
Feb 4, 2009 09:22 PM
