54 Meadowbrook Cooling System
Old Oct 4, 2025 | 05:15 PM
jryan@t6b.com's Avatar
Hi,
Car has been parked since 1966. Pulled head to free up some stuck valves. Triple checked replacement head gasket to make sure it was right.
Coolant in radiator and in top half of engine as I fill radiator and can squeeze top hose and coolant comes out of radiator. Have a freeze plug out and there is no coolant in the block. Freeze plug came out when blowing air in the block drain with radiator cap off, blew plug out. How could there be now flow at all, in fact plugged between radiator and block?
Thanks
Old Oct 6, 2025 | 12:15 PM
One bad freeze plug says you need to replace all of them after setting all those years.
Old Oct 7, 2025 | 08:00 AM
Sounds like the thermostat is frozen shut
Polie
Sep 8, 2022 05:09 PM
trez681
Aug 31, 2018 02:31 PM
dick jacobs 34
Member question and comments about MoparForums.com
Sep 6, 2016 01:42 PM
hckrphil
Jun 17, 2014 09:53 AM
DartSwinger
Oct 11, 2010 01:58 PM
