Rear axle upgrade for 58 dodge coronet
Old Nov 16, 2024 | 03:48 PM
Acer123's Avatar
I have a 58 dodge coronet and I want to upgrade my rear axle to something with disc brakes. Is there a place I can buy a new axle that matches the same dimensions and with disc brakes or do I need to find a used axle from a different car that's close to the original?
Old Nov 16, 2024 | 04:20 PM
Look at newer Jeeps, if you find one that will work make sure you get the park break cables and possibly the driveshaft. You will probably need to have the driveshaft modified or a new one fabricated.
good luck
Old Nov 17, 2024 | 09:55 PM
Acer123's Avatar
good luck
Do you know what range of years of jeeps would work?
Old Nov 17, 2024 | 10:08 PM
I don’t know what year they went to rear disks but I know the Jeep liberty is a popular rear axle. I would start by measuring the axle in your car now from Will moaning surface to wheel mine surface and then try to find an actual same width Plus or -1/2 inch…
Old Nov 18, 2024 | 10:16 AM
Find a place like this to help you with a replacement.... https://www.currieenterprises.com/?u...SAAEgL1_vD_BwE
Old Nov 18, 2024 | 03:41 PM
It sure is fun spending others money right Bob?
Old Nov 18, 2024 | 03:45 PM
I’ve been thinking about the Jeep deal and the Jeep brakes will fit the axle assembly you have. They have an aluminum backing plate that includes a parking brake and caliper mount that you can just replace the drum brake backing plate with. It’s a nice swap.
Old Nov 19, 2024 | 08:41 AM
Yep..... Thats the easy part.....
Old Nov 19, 2024 | 08:45 AM
You could go help you know.......
vht
Dec 3, 2019 07:47 PM
randy4662
Aug 27, 2015 05:29 AM
mopar318
Feb 13, 2013 10:35 PM
Cure
Oct 9, 2009 12:04 PM
Jul 24, 2009 09:20 AM
