1986 Dodge Ram Truck
Guest
Posts: n/a
I have a 1986 Dodge Ram Truck. The problem that I am having is the blower does not get any power from the switch. I straight wired the blower from the battery and it works. Is there a way that I can check to see if power is going to the switch? I have tested serveral wires and I cannot find any power going to the switch. I guest that I haven't found the right wire yet. All the fuses are good.
I checked the fuse block under the dash and there is no power going to the blower fuse. I cannot find a fuse in the engine compartment. Is there a fuse or could it be something else?
Guest
Posts: n/a
Blower motor on 1986 Dodge Ram
I replaced the ignition switch and the blower works. Now the only problem that I have is this. When I went back to put the dash and the a/c and heater control back, I found a 7 wire plug and I cannot find another plug for it to plug into. What does this plug go into?
Guest
Posts: n/a
I have a 1986 Dodge ram custom 150 pick up. I have changed the alternator. plugs,distributer cap and rotor, electrical seleniod box on firewall. a newly charged battery. Changed the Fuel pump, fuel filter. and fuel lines. and put in a used 2 barrell carburator. it still wont start. the only thing I have noticed is there is a fuseable link on the driver side of the truck in the engine compartment with one wire in from the direction of the batery out to 4 wires. One of the wires id burnt out and i have replaced it with a 14 guage fuseable link wire. can you tell me what I need to do to get the truck running again? It was woriking fine up til now. the engine turns when I turn the key and I have gas in the tank. I have primed the carburator and it started once but wont start again.
Guest
Posts: n/a
you need fuel spark and compression.
have you check for gas when you open the throttle?
have you checked for a spark when cranking?
have you checked that the rotor still points the the #1 cylinder when the crank is at TDC?
have you checked the battery voltage when cranking?
reading up on how things work in you vehicle could have saved you a lot of time and money.
Most car manufacturers of the time (and now) will put a generic wiring harness into a car that will fit whatever trim package they are installing. Does your plug have dust or corrosion on the face of it? If so then it hasn't been plugged into anything for a long time and you need not worry about it. Otherwise go with scotts74birds suggestion and see what doesn't turn on anymore.
Good luck!
Good luck!
customaesthetics
08-07-2012 06:13 AM
