360 heads on a 316????????????
Old Aug 15, 2010 | 06:28 PM
DustinHeck's Avatar
Question 360 heads on a 316????????????
I just got a new 318 short block from mopar nationals this weekend i was wondering if i could put 360 heads on it some one told me to do that for more power or some thing like that he was talking real fast so i did not get what all he said
Old Aug 15, 2010 | 06:56 PM
1966sportfury's Avatar
A.K.A Bob Dodge
you will get better flow due to the bigger valves but will lose HP due to the comp ratio will be lower, depends on what pistions you have
Old Aug 15, 2010 | 07:06 PM
DustinHeck's Avatar
i think there stock flat top pistions
Old Aug 15, 2010 | 07:07 PM
DustinHeck's Avatar
would it be worth it then
Old Aug 15, 2010 | 08:29 PM
A.K.A Bob Dodge
its a toss up, what i would do is measure pistion to deck height, then do the math and see what you come up with, probly around 7.5:1, which wouldnt be a very powerfull engine. but with that low of compression you could add turbos
Old Aug 16, 2010 | 08:18 AM
DustinHeck's Avatar
ok thanks
Old Aug 16, 2010 | 08:34 AM
Is the short block complete? If it needs to be torn down, that would be the time to install some different pistons. Of course, you could always just trade it towards a 360 and not have to worry about this issue.
Edit: I saw that you already have a 360 in there. Get rid of the 318 and just build the 360. Or get another 360, build it, then swap it in.
Old Aug 17, 2010 | 09:25 AM
DustinHeck's Avatar
yes it just needs the top put together i got the 318 cheap and my 360 smokes sometimes and sometimes it dont but i dont know why because it only has 93k so i was going to put my heads on it and drop it in but ill just do what you said ill try to get a 360 so it stays original
Old Aug 17, 2010 | 09:53 AM
For some reason(s) that I do not understand, the cylinder heads on teh truck 318s and 360s need to be rebuilt about every 75,000 miles. Don't ask me why (well it's because the seals go and the vlaves need to be lapped) but they do. I'd look into that or trade teh 318 block for a set of 360 heads.
Old Jan 25, 2011 | 10:48 PM
deadbird54's Avatar
just change the cam shaft
Old Jan 25, 2011 | 11:06 PM
A.K.A Bob Dodge
if it smokes sometimes and some times not, more than likely the valve guides are worn.
Old Jan 28, 2011 | 02:04 PM
chlngr1970's Avatar
See if you can find the later heads with the heart shaped combustion chamber ( LA heads, late 80s ) and get those done. I don't know the casting numbers, sorry...
j
Old Jan 28, 2011 | 03:16 PM
blue 68 gts's Avatar
Yep, or comp rings are starting to go.
AlexMacTools
Feb 10, 2010 06:36 AM
getsum
Dec 10, 2009 10:01 AM
1973charger
Jun 4, 2009 09:46 AM
lail12
May 26, 2009 07:20 PM
devilkin4
May 23, 2009 12:31 AM
