88 D100 Oil Pressure issues...help/suggestions.
Old Oct 2, 2009 | 09:56 AM
74Duster's Avatar
Junior Member
Try a windage tray?
Old Oct 2, 2009 | 03:28 PM
scotts74birds's Avatar
My 318 95 Ram w/ 240k does that. I changed the oilpump, same issue. Switched from 1-30 to 10-40, that helped some. When I had the pan off I should have plastigauged the rod and main bearings. A reliable source told me thats where I could lose alot of pressure. I also had a coolant leak into my oil which diluted it some, any foam in your, or on the dipstick? I seldom have heard anything about bad cam bearings, but anything can happen. Good luck.
Old Oct 3, 2009 | 03:10 PM
Well now you know its probably an internal engine issue. Might as well band-aid it till you can do something about it. Thicker oil. Make sure your oil isnt being diluted either by gas from blowby, or even a bad fuel pump. That will thin it out.
Old Oct 3, 2009 | 03:25 PM
Craigslist is a great place for motors. But yeah, do your homework before writing off the motor.
Skynyrd
Sep 10, 2014 05:24 PM
67Polara
Aug 27, 2009 10:35 AM
dzltd02
Oct 28, 2008 08:25 AM
sixpackchris01
Oct 8, 2008 12:55 AM
64fury
Jun 14, 2008 06:48 AM
