99 dodge ram surging
Old Sep 15, 2010 | 07:49 AM
gotdust's Avatar
i have a 99 dodge ram 5.2 litre auto trans with overdrive and lately i have started getting a surging after i get to overdrive, it is not a miss just like a power surge, it doesnt do it before the overdrive just after about the 45mph and above range, also it will do it with overdrive on or off, could this have something to do with never changing fluid and filter in trans, i bought new and it has 111000 miles on it,would be thankful for any help
Old Sep 15, 2010 | 09:13 AM
Get the filter changed and have the system flushed. The trannies in these truck should be serviced (filter and fluid changed) every 30,000 miles.
Old Sep 15, 2010 | 11:27 AM
gotdust's Avatar
thanks, anyone else want to give thoughts i am sorta thinking myself it is trans fluid
Old Sep 15, 2010 | 11:52 AM
1966sportfury's Avatar
A.K.A Bob Dodge
i dont know much about these yrs, but by reading the title i was thinking throttle position senser,? but again i dont know, good luck
Old Sep 15, 2010 | 12:05 PM
gotdust's Avatar
the funny thing is there is no engine check light coming on and other then that it is running like new truck
Old Sep 15, 2010 | 12:10 PM
A.K.A Bob Dodge
ive had the TPS go out and check engine lights wouldnt show a problem,
Old Sep 15, 2010 | 12:53 PM
gotdust's Avatar
i just hooked up my actron code scanner and it shows no code errors says system is ok
Old Sep 15, 2010 | 07:29 PM
mod381's Avatar
sounds like bad tps causing tcc to lock and unlock. Does engine rpm also change 200-500 rpm?
Old Sep 16, 2010 | 08:21 AM
gotdust's Avatar
yes that is what about how many rpms it changes where is tps senson located and how hard is it to change thanks and maybe cost
Old Sep 17, 2010 | 07:48 AM
gotdust's Avatar
well i changed tps sensor and still the same problem any other ideas thanks
Old Sep 18, 2010 | 03:26 PM
scotts74birds's Avatar
If you have the basic Actron [under $100] it probably wont show you ****. I am leaning with mod381 about the lock-up going in and out. In addition to the actual lock-up mechanism, there are a number of external inputs to the PCM that it uses to decide when to, and when not to, lock the convertor. Could be any of a number of sensors giving a bad reading. Does the key on-off-on-off-on trick work on your truck? This will sometimes display other P codes in the digital odometer display.
Old Sep 19, 2010 | 02:14 PM
gotdust's Avatar
havent tried the on off key method yet thanks
Old Sep 19, 2010 | 06:07 PM
MoparOnly's Avatar
Have you changed the trans fluid yet??? I've got a 95 Ram 1500 with 132,000 miles that I bought new. I change the fluid every 30,000 as 78D200 suggested and have had no problems (knocking on wood here). Be sure to check the owners manual for the correct TYPE of fluid... very important!!!
t/s1148
Apr 29, 2015 11:09 AM
traveeee
Sep 8, 2014 10:41 AM
gotdust
Sep 30, 2010 06:04 AM
91shadowTurbo
Aug 9, 2010 05:30 AM
balfour_17
Jan 8, 2008 11:21 PM
