How well can an '94 5.2 Magnum survive a single very serious overheat?
Old Dec 18, 2019 | 10:13 AM
Mark J Sherrell's Avatar
Long story short, a client of my mother's has an 1994 Ram 250 van with a 5.2 Magnum engine, and it blew a water pump, and was overheating 5 miles from it's destination visibly. The water pump totally shot to the point cooland poors out fast as you pour it in.
It's stuck in a hospital parking lot (owner poor, dying, and it has necessary wheelchair lift in it). I may have to fix it in the parking lot of the Health Department across the street (I got the serpentine back on, took batter home and fully charged it, it's dead cold so it can make it), and I plan to compression test it later. I can't have antifreeze leaking in the hospital lot, cops would surely frown on it, but I have leeway (and their permission) in the combo HD/supermarket lot. Plus I have an oil collector to catch most of it. (new one cuz the antifreeze looks clean and will maybe re-use some).
Do you guys think a '94 Magnum 5.2 can drive five miles AFTER visible steam leaks and belth thrown, in 45 degree (F) weather and not blow gaskets? Thanks, I will know soon enough, but thought I'd ask.
Also, if it has air conditiooning lines blocking it, how does one remove the fan shrod without cutting it? Thanks.
Old Dec 19, 2019 | 08:33 PM
Last question first, you remove the fan shroud by removing it and setting it back then remove the fan, then remove both from the vehicle at the same time.
As to the overheating the only way to find out is put a water pump on it and give it a try, the heads are prone to cracking normally, just something to be aware of.
Nathan Jorgenson
Jan 11, 2019 08:46 PM
David 1863
Sep 23, 2017 03:22 PM
dave00143
Dec 31, 2013 12:45 PM
trk1363
13
Jan 29, 2012 03:42 AM
Chall70
Sep 23, 2008 07:39 AM
