loud whineing faster u go louder it gets
Old Apr 27, 2018 | 02:07 PM
Bruce Cameron's Avatar
Question loud whineing faster u go louder it gets
08 dodge ram 1500,106,897miles,has loud whinging noise faster u go louder it gets,jack up rear run it ,no sound,checked u joints,checked fluid,gets so loud u can`t talk normal at high speedut like i said,we jacked it up an ran it an no noise,any idea`s ,thinking pinion bearings or wheel bearing ,same tires for 5 years,
Old Apr 27, 2018 | 02:22 PM
My guess would be axle bearing...
Old Apr 27, 2018 | 03:42 PM
If it's a 9 1/4" they're prone to crush sleeve collapse and loose front pinion bearing. Grab the yoke and push up and down hard, that will show you.
Old Apr 28, 2018 | 08:21 PM
Hottboy's Avatar
Dont over thinkit.
Sounds like the belts. Strain on the crank when drive wheels are sitting on the ground and the belts are slipping. But when you lift the drive wheels the engine has less strain and the crank doesn't work as hard so the belts dont slip
Old Apr 28, 2018 | 09:17 PM
maybe load it with an application of brake, or check the front wheel bearings
68 RT
Mar 26, 2017 10:24 AM
Magoo
Aug 22, 2015 12:25 PM
Misteroadrunner69
Mar 12, 2014 12:57 PM
moe7404
Feb 25, 2014 06:38 PM
67hemidart
Apr 26, 2012 07:18 PM
