Soft pedal 2006 mega cab
Old Feb 12, 2013 | 05:18 PM
bigblue's Avatar
Has anyone else had an issue with the brakes? The pedal goes to the floor after holding it with minimal pressure. No lights, no recalls associated with my vin. New front rotors and pads, new master cylinder, bled brakes and ABS with computer. Better but still going to the floor.
Old Feb 12, 2013 | 06:05 PM
Mr.4spd's Avatar
So this stuff was replaced to try and correct this issue? Or did the issue come up after? Sounds like a leak or air in the system.
Old Feb 12, 2013 | 07:08 PM
bigblue's Avatar
Replaced attempting to correct the issue. Sounds like the techs never got air to bleed from either method. No leaks obvious no fluid visible on components or the floor.
Old Feb 23, 2013 | 10:31 AM
mikerp76's Avatar
4 wheel disk or drums in the rear? does it do it with the key on or off or both?
thomasmcnulty
May 24, 2011 07:23 AM
67Polara
Jul 17, 2010 05:14 PM
67Polara
May 17, 2010 06:47 PM
67Polara
May 8, 2010 08:16 PM
deadkelly
Aug 9, 2008 08:28 PM
